delta fence for JET saw
Forum topic by jamfu posted 11-17-2015 01:31 AM 562 views 0 times favorited 5 replies Add to Favorites Watch
View jamfu's profile
jamfu
23 posts in 925 days
11-17-2015 01:31 AM
Can a delta fence system easily be adapted to fit a JET tablesaw? im looking at a DELTA 36-T30 T3 30-Inch Fence with a reasonable price. Is this advisable, or any one know of any major difficulty?
Jim
5 replies so far
View alittleoff's profile
alittleoff
539 posts in 1274 days
#1 posted 11-17-2015 04:09 AM
As long a the width is the same I don’t know of any reason that it wouldn’t work. I not a expert but I think it would. You will probably have to do some drilling on the rails or saw table though.
Gerald
View MrUnix's profile
MrUnix
6710 posts in 2197 days
#2 posted 11-17-2015 04:14 AM
The Biesmeyer fence (which is basically what that Delta is) will mount on just about any saw with a little creativity. Yes, you will most likely have to drill some holes, but drilling cast iron is easy. The old installation manuals used to have specific instructions for Delta and non-Delta machines. Not sure if the new ones do or not.
View TheFridge's profile
TheFridge
9460 posts in 1484 days
#3 posted 11-17-2015 05:04 AM
Pretty easy if you have a bit of mechanical inclination. Just understand the relationship of how high or low the fence is supposed to sit on the rail so the fence sits in the table evenly and properly.
View Jim B's profile
Jim B
58 posts in 1228 days
#4 posted 11-17-2015 05:15 AM
I have a Jet JWTS-10JF that I put a Delta T2 on. It didn’t require any modifications to either. The holes in the table were ever so slightly different than those in the rails, just enough so the screws didn’t sit perfectly flush. It still functions perfectly though. It was a good upgrade from the stock fence.
jamfu
#5 posted 11-17-2015 10:57 AM
great thanks guys . i just dont have enough experience with this to know .
Jim
