Today's MDF is soft?
Forum topic by MattinCincy posted 12-26-2009 01:08 AM 1181 views 0 times favorited 5 replies Add to Favorites Watch
View MattinCincy's profile
128 posts in 3084 days
12-26-2009 01:08 AM
I recently ran across some old templates that I made from 1/2” MDF about 15 years ago and noticed that it was much denser and harder than the stuff I am buying at HD and Lowes. Have the standards changed or has quality just lapsed over the years? I would really like to find a source for 1/4”, 1/2” and 3/4” material like I used to get years ago – anyone know where to get it?
-- Wag more, bark less.
5 replies so far
View Ger21's profile
1074 posts in 3062 days
#1 posted 12-26-2009 01:27 AM
Different manufacturers make different grades of MDF. The stuff Home Depot sells is the cheapest available. I work in a big cabinet shop. We get mdf from a couple different distributors, from a few different manufacturers. They are all a lot better then the Home Depot stuff.
-- Gerry,
dennis mitchell
3994 posts in 4245 days
#2 posted 12-26-2009 01:45 AM
The same with particle board. Some you can break apart with your hand and when you cut it it leaves a ragged edge. The good stuff leaves a nice square clean cut. It is much harder to kick a hole in the back of a cabinet made with the good stuff. Cost about one dollar more per cabinet, but almost all prefabs use the cheap stuff.
View GFYS's profile
711 posts in 3402 days
#3 posted 12-26-2009 03:49 AM
You do realise there are various densities of “mdf” fact..mdf is Medium Density Fiberboard
#4 posted 12-27-2009 03:27 AM
Gerry – do you know any of the manufacturers’ names or where I might be able to get some of the good stuff? I’m not a big user, I might only want one sheet each of 1/4”, 1/2”, and 3/4”. Also, without seeing it, how do you know what to buy if purchasing online? It would be impossible to discern how dense it is.
117029 posts in 3508 days
#5 posted 12-27-2009 04:14 AM
Try a real lumber yard not a box store an ask for the cabinet grade.
-- wood crafting & classes
