how to build a woodworking vise
Forum topic by Guillermo posted 12-25-2009 11:51 PM 70970 views 12 times favorited 16 replies Add to Favorites Watch
View Guillermo's profile
Guillermo
5 posts in 3036 days
12-25-2009 11:51 PM
I came across a posting from a fellow named Joe, I believe, about building your own bench vise from scratch, but can’t find it again. Does anybody, including Joe, know how to build his own woodworking vise?—buying the hardware, the screw etc.? I think Joe said something about about plumbing joints, and that’s what I’ve been thinking of. Thanks.—Guillermo
-- Guillermo, Mexico
16 replies so far
View AaronK's profile
AaronK
1506 posts in 3426 days
#1 posted 12-26-2009 12:33 AM
i’ve built one from two pipe clamps – is this the sort of thing you’re talking about? i can post pics and links if youre interested
View bigike's profile
bigike
4050 posts in 3251 days
#2 posted 12-26-2009 12:40 AM
im interested?
AaronK
#3 posted 12-26-2009 01:20 AM
check out
http://www.angelfire.com/music2/construct/bnchthmb.html
and
http://www.ncwoodworker.net/forums/f81/workbench-4-foot-twin-screw-vise-cheap-15033/
mine is a little bit different – not as awesome a design since it doesnt have the 4 ft of travel and foot pedals! it’s more like the “new fangled workbench” by FWW (google if you arent familiar with it). The main thing about building a vice from pipe clamps is that you need to be able to keep the pipes parallel to the bench top surface… the way you would any vice i guess. it works though, and better than i expected. by vise has about 12-14” of space between the pipes and will easily hold a 6+ ft board for edge jointing by hand. surprisingly effective!
i’ll try to get pics of mine up within the next few days if you want.
AaronK
#4 posted 12-26-2009 01:21 AM
of course there are many more professional options out there – you can buy “real” vise hardware and custom make the wooden parts to fit your bench…
View Ger21's profile
Ger21
1074 posts in 3093 days
#5 posted 12-26-2009 01:30 AM
Guillermo
#6 posted 12-26-2009 01:33 AM
Thanks for the input. I’ll keep the pipe-clamp method in mind. I’m living in Mexico (doing missionary work) and have seen some big threaded rods, like 3/4” or even bigger. I was thinking of getting a meter, say, of one of these, and cutting it in half and making two vises. But what I’m wondering is what do I fit the threaded rod into? I suppose I could have something machine made but I’m on a pretty limited budget. I’ve never seen anywhere where anyone made his own vise from scratch. I owned a beautiful Swiss-made workbench when I was living in South Africa, and I’m familiar with the mechanics of the end and shoulder vises, but would something like what I’ve described (a 3/4 or one-inch threaded rod) be OK and not too rickety?
TopamaxSurvivor
18241 posts in 3638 days
#7 posted 12-26-2009 06:38 AM
If you file some knotchs in the 3/4 rod and taper it a little with a file, you can use it to tap the holes to thread into.
View Navtrtl's profile
Navtrtl
17 posts in 3042 days
#8 posted 12-26-2009 07:17 AM
I looked at that Big Wood Vise site posted above. Bout had a heart attack. That stuff ain’t cheap. I’m sure it’s quality stuff, but man my wallet ran off when I saw the prices.
-- US Navy Veteran Morgantown, KY
View bladeburner's profile
bladeburner
88 posts in 3049 days
#9 posted 12-26-2009 03:20 PM
Pipe clamp vises do work. This one has been on this leg vise for over 40 years. The bottom stop was 1/4” hardwood at first, but after I was able to get carbide router bits I replaced it with aluminum.
Leg vise 1
Leg vise 2
View jmd199's profile
jmd199
2 posts in 2987 days
#10 posted 02-13-2010 04:14 AM
I noticed the earlier comment regarding wood vise screws and just as a heads up that Lake Erie Toolworks is a new company headed by Nick Dombrowski – website: www.lakeerietoolworks.com that offers the largest wood vise screws and related wood vise screw kits available on the market today.
There’s also review of the wood vise screw by Christopher Schwarz by following this link:
http://blog.woodworking-magazine.com/blog/New+Wooden+Vise+Screws+From+Lake+Erie.aspx
Take care,
Jeff
jmd199
#11 posted 02-13-2010 04:16 AM
Link for Lake Erie Toolworks – Wooden Vise Screw Kits
http://www.lakeerietoolworks.com
117060 posts in 3539 days
#12 posted 02-13-2010 04:18 AM
Wow lots of great tips.
View JoshJock's profile
JoshJock
94 posts in 2805 days
#13 posted 08-19-2010 02:43 AM
Love the pipe clamp idea!! I’m going to implement it on my project workbench…! ty for the post.
-- "Does this lathe makes my butt look big?"
View jeth's profile
jeth
258 posts in 2800 days
#14 posted 08-19-2010 05:34 AM
First post here on the forum so hello all.. If you look down the page on this link you’ll see a “tornillo de carpintero” or carpenters screw, these are available in most “ferreterias” (or hardware stores, sorry, not sure how much spanish you speak) down here in the far south, where what IS available is far more limited than in other locations, so I’m guessing they should be easy enough to find where you are based. This is a prefabricated vise screw and will sot you about the same as a set of pipe clamp heads, but you won’t have to buy the pipes or fiddle so much to fit them to a bench. The norm here is a crude leg vise using one of these, with no pivot guide at the bottom to speak of. I’m planning my first (decent) bench and will probably use a few of them to make a twin screw face vise and a single screw end vise.
Good luck..
View Greedo's profile
Greedo
473 posts in 2923 days
#15 posted 08-19-2010 07:27 AM
i’v made my own vises completely from scratch: http://lumberjocks.com/projects/35387
the in kit hardware some suggest is not the kind of thing you find in the store around the corner, unless maybe in the states!
