Both Sides
Forum topic by mark76wa posted 11-16-2015 10:28 PM 661 views 0 times favorited 3 replies Add to Favorites Watch
View mark76wa's profile
mark76wa
97 posts in 3304 days
11-16-2015 10:28 PM
I have this slab of Cherry. It was cut from my sister’s front yard several years ago. It has been air drying for about 2.5-3 years.
I made a router sled to flatten on side. It how has a high side of 2-13/16” and a low side of 15/16”. I kind of want to keep onside unfinished as a design detail and make a live edge table. I have some bird’s eye maple for the legs.
Will I run into any issues if I flatten one side and only sand the other side?
3 replies so far
View TiggerWood's profile
TiggerWood
271 posts in 1515 days
#1 posted 11-16-2015 11:10 PM
I’ve seen it professionally done that way on many tables.
View OSU55's profile
OSU55
1524 posts in 1898 days
#2 posted 11-17-2015 01:33 AM
Machining one side and sanding the other is no issue, but be sure to seal the bottom with the same finish used on the top to even out moisture movement.
View HokieKen's profile
HokieKen
4625 posts in 1047 days
#3 posted 11-17-2015 06:05 PM
Like OSU55 said, just make sure both sides are balanced for moisture.
-- Kenny, SW VA, Go Hokies!!!
