Aluminum VS Phenolic for router table plate
Forum topic by wooddan posted 12-24-2009 11:54 PM 8953 views 1 time favorited 16 replies Add to Favorites Watch
View wooddan's profile
wooddan
4 posts in 2984 days
12-24-2009 11:54 PM
I was thinking about building a new router table. Any thought on which way to go? I will be using my Freud 2 1/4 horse.
-- Dan
16 replies so far
View surfin2's profile
surfin2
51276 posts in 3038 days
#1 posted 12-25-2009 03:32 AM
I went with aluminum, it’ll hold up alot better in every way than phenolic…
-- Rick
View drfixit's profile
drfixit
318 posts in 3046 days
#2 posted 12-25-2009 04:10 AM
Mine also is aluminum, went a step further and used 1/4” aluminum over 2 layers of 3/4” mdf for the top that the plate sits in.
-- I GIVE UP!!!! I've cut this @!&*!% board 3 times.... its still too short!
Rick Dennington
5687 posts in 3096 days
#3 posted 12-25-2009 04:32 AM
Greetings wooddan: I think you will find most of the guys on here prefer the aluminum plates pretty much over the others. I use the alumnium plate from Rockler—I have 2, in fact. I’ve used phenolic,and have used other types in the past, like Rousseou, and they are a good plate, but phenolic. I think you will be much happier going with the 1/4” alumnium plate. I did the same thing that drfixit did. Makes a good strong top.
-- " Don't pet the sweaty things, and don't sweat the petty things."
View araldite's profile
araldite
188 posts in 3306 days
#4 posted 12-25-2009 04:44 AM
I had phenolic in my table for a number of years with a router hanging from it the whole time. Recently I was checking the flatness of my table and discovered the table was still flat but the plate had warped slightly. I just got in a new aluminum plate the other day and will be making the switch.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View Sacadelic's profile
Sacadelic
43 posts in 3198 days
#5 posted 12-25-2009 06:23 AM
I would highly recommend the aluminum. I had the phenolic and it warped pretty badly real quick. The router that I am using is a 3 1/4 HP Freud. I just ordered an aluminum plate form MLCS to replace my existing one. Good luck.
-- Sac
View Pete_Jud's profile
Pete_Jud
424 posts in 3655 days
#6 posted 12-25-2009 06:59 AM
I only use the phenolic bases as portable anymore they will warp, go with the aluminum.
-- Life is to short to own an ugly boat.
View John Gray's profile
John Gray
2370 posts in 3788 days
#7 posted 12-25-2009 08:05 AM
ALUMINUM!!!!!!!!!!!!!
View mikedddd's profile
mikedddd
147 posts in 3132 days
#8 posted 12-25-2009 08:34 AM
Wooddan:
I have had the same issues with the Phenolic plate as others here don’t waste your time and money go with the Aluminum plate the first time.
Mike
-- Mike
View woodworm's profile
woodworm
14454 posts in 3493 days
#9 posted 12-25-2009 12:41 PM
Table mounted : aluminum
Handheld : clear acrylic(plastic) for visuality
-- masrol, kuala lumpur, MY.
View Ger21's profile
Ger21
1074 posts in 3033 days
#10 posted 12-25-2009 04:09 PM
Good quality phenolic plates work fine. I’ve been using two Woodhaven 3/8” phenolic plates for over 10 years, and they are still perfectly flat. One of them has a 7518 hanging from it, and those things are heavy.
http://woodhaven.com/Woodhaven-141-Large-Router-Plate/M/B001NZ0MJK.htm
http://woodhaven.com/Woodhaven-148-Large-Blank-Router-Plate/M/B002LTWGBO.htm
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
surfin2
#11 posted 12-25-2009 06:50 PM
I don’t see anything for inserts,...
Aluminum plates come with all sizes for what ever floats your boat…
Rocklers can also be used on there[ http://www.rockler.com/product.cfm?page=19741]
universal plate…
-- Rick
View Chris 's profile
Chris
1879 posts in 3893 days
#12 posted 12-25-2009 07:02 PM
Aluminum here as well… 1/4” thick from rockler…..
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View GaryK's profile
GaryK
10262 posts in 3890 days
#13 posted 12-25-2009 07:19 PM
I bet you’re going to go with aluminum now, huh?
It stays nice and flat. I haven’t seen a plastic or phenolic that stayed perfectly flat like aluminum.
The weight of a router hanging on it 24 hours a day as an effect.
View richgreer's profile
richgreer
4541 posts in 2977 days
#14 posted 12-25-2009 07:33 PM
The best advise I can give you is to don’t buy a insert plate at all. Buy a lifting mechanism. Woodpecker offers several variations. I have the Quick-Lif and it works great. It allows ultra fine height adjustments and you can “pop” the router to the top for easy bit changes in a few seconds.
wooddan
#15 posted 12-25-2009 11:22 PM
Thanks for all your input everyone! I was planning on aluminum to start with, but saw all the different phenolics and thought I would ask.
Thanks for the input Rich. I would love to go with a lift, but it’s not in the budget(especially after Christmas!!). Maybe next year.
-- Dan
