240 Volt electrical question
Forum topic by Julian posted 11-16-2015 02:12 AM 1126 views 0 times favorited 24 replies Add to Favorites Watch
View Julian's profile
Julian
1347 posts in 2715 days
11-16-2015 02:12 AM
Topic tags/keywords: question
I just purchased a 3 hp Jet table saw and the plug has 3 prongs. I have a 240V circuit in the garage but that outlet has 4 prongs (for a 5hp drum sander). The outlet for the drum sander has 2 black wires, 1 white, & 1 green.
I want to install another outlet next to this one. If is use 1 of the black wires, the white and green will that work?
I don’t want to make a mistake and burn up my TS motor.
-- Julian
24 replies so far
View johnstoneb's profile
johnstoneb
2938 posts in 2197 days
#1 posted 11-16-2015 02:25 AM
Given the question you’re asking and how you are asking it. Hire an electrician. He’ll wire it up in a few minutes not to much money and won’t burn your house down or electrcute You.
-- Bruce, Boise, ID
View TheFridge's profile
TheFridge
9608 posts in 1511 days
#2 posted 11-16-2015 02:26 AM
Use both blacks for 240v
1 black and 1 white will prob be 120v
I’d check with a meter.
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#3 posted 11-16-2015 02:27 AM
Typically, the two blacks should be the hots, the white is neutral and green is ground. A meter can quickly verify. If so, then you would use the two blacks (hots) and green ground. The white neutral will be unused.
View crank49's profile
crank49
4032 posts in 2996 days
#4 posted 11-16-2015 02:45 AM
You can’t depend on the color of wires to determine voltage.
No way to know whether the person hooking them up was an electrician or some body else like you that has to ask this question.
Or, at the very least buy a voltmeter and a book on wiring.
Julian
#5 posted 11-16-2015 04:47 AM
The 240V outlet was installed by an electrician. I’ll check with my meter. This is not rocket science. Thanks for the advice.
-- Julian
View DIYaholic's profile
DIYaholic
19623 posts in 2700 days
#6 posted 11-16-2015 04:51 AM
True this is not “rocket science”....
However, I’ve seen live video of NASA rockets exploding!!!
TheFridge
#7 posted 11-16-2015 05:37 AM
The 240V outlet was installed by an electrician. I ll check with my meter. This is not rocket science. Thanks for the advice.
- Julian
No problem. Some are cautious. Some actually are electricians.
View rwe2156's profile
rwe2156
2964 posts in 1505 days
#8 posted 11-16-2015 12:56 PM
You can t depend on the color of wires to determine voltage.
- crank49
What ^ he said X 10!!
My advice: if you’re electrician tells you its ok, get another one!
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1201 days
#9 posted 11-16-2015 01:22 PM
Most (some?) electrical codes require 240V to be a direct run from a single outlet back to the breaker box. At least here in Missouri that is the rule.
Your idea will work, assuming you use the correct wires, but may not be code. This will cause problems if you get an electrical inspection or if you make an insurance claim.
As others have said it is better to hire an electrician.
View HokieKen's profile
HokieKen
5229 posts in 1163 days
#10 posted 11-16-2015 02:28 PM
If it were me, I’d either replace the plug on the table saw or make a pigtail to adapt that plug to the existing outlet. Much cheaper than paying an electrician to run another outlet.
And, I think WoodNSawdust is correct. If I remember correctly, your only allowed 1 outlet/circuit for 230V.
-- Kenny, SW VA, Go Hokies!!!
View hhhopks's profile
hhhopks
651 posts in 2402 days
#11 posted 11-16-2015 03:38 PM
I like Kenny’s idea, a conversion plug and should be the cheapest. There will be no wire from the saw to the neutral wire (white) position. You can only operate one tool at a time. Right?
-- I'll be a woodworker when I grow up. HHHOPKS
4999 posts in 2518 days
#12 posted 11-16-2015 04:21 PM
You guys that think you can’t have multiple outlets on a 20A/240V circuit aren’t referring to the NEC ( I think 30 amp are OK as well). There is (was) nothing in there that prohibited multiple 240V outlets on a single circuit, although some localities might have stuck that in their requirements.
HokieKen
#13 posted 11-16-2015 05:08 PM
You guys that think you can t have multiple outlets on a 20A/240V circuit aren t referring to the NEC ( I think 30 amp are OK as well). There is (was) nothing in there that prohibited multiple 240V outlets on a single circuit, although some localities might have stuck that in their requirements.
- Fred Hargis
You’re right (for VA anyway). I just looked at the code. I thought line-line circuits could only service 1 outlet but according to VA code, as long as all ungrounded conductors are opened simultaneously by the breaker (2-pole breaker), you can run multiple outlets.
I’d probably still opt for a new plug or converter but since it’s a conduit install, it would be a simple thing to throw a junction box in there and run a second outlet.
#14 posted 11-16-2015 05:33 PM
When I wired my shop I put in 5-240V circuits. One for the DC is dedicated, but the others (3-20A, 1-30A) are all multiple outlet circuits….and when I did it I checked the NEC and found no problems with the practice.
Julian
#15 posted 11-16-2015 05:43 PM
Kenny; I will use your idea. Just change out the plug on the cord to fit the existing outlet. The neutral prong will not be connected on the TS cord. I will never need to use the table saw and drum sander at the same time. This will be less work and $. Thanks Kenny.
-- Julian
