which used 6" jointer
Forum topic by scribble posted 11-16-2015 12:32 AM 771 views 0 times favorited 2 replies Add to Favorites Watch
View scribble's profile
scribble
204 posts in 2436 days
11-16-2015 12:32 AM
Topic tags/keywords: question jointer
I have 4 used 6” jointers for sale in my area and all are in good usable shape with nothing a little cleaning and tune up can’t fix. I am just not sure what one would be better. the prices are the current asking but I will be able to dicker on each on a bit
Delta JT360 $300
delta 37-190 $275
powermatic 50 $350
ridgid jp0610 $350
Thank You for your help in making my decision.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
2 replies so far
View TheGreatJon's profile
TheGreatJon
340 posts in 1469 days
#1 posted 11-16-2015 01:38 AM
Assuming they are all in good working order, I would definitely go for the PM50. No question. It is older, but it is also heavier and made with higher quality standards. Heaviness makes it harder to move, but cuts down on vibration and gives you a better cut. It will far out last the other three. Of the three newer models, I would go for the rigid. It gets great reviews.
That being said, they won’t all be in equal condition. Whichever one you go to look at, be sure to run some wood through it, listen for odd noises, listen for the motor pitch to remain unchanged when you test it, bring a straightedge and check the flatness of the beds.
-- This is not the signature line you are looking for.
View BobHall's profile
BobHall
45 posts in 1521 days
#2 posted 11-16-2015 02:10 AM
PM 50 !!
-- Bob "jack of all trades, master of none"
