Rabbets
Forum topic by ArtCam posted 11-15-2015 11:05 PM 761 views 0 times favorited 9 replies Add to Favorites Watch
View ArtCam's profile
ArtCam
20 posts in 890 days
11-15-2015 11:05 PM
I am an artist and make my own picture frames.
www.artderek.com
So, I have to make a lot of rabbets. What is your preference: the table saw, or router?
And….why.
Thanks, Derek
9 replies so far
View MrUnix's profile
MrUnix
6587 posts in 2164 days
#1 posted 11-15-2015 11:24 PM
I make frames for my scroll saw portraits and found that using the router table works best for me. Easier to setup and generally leaves a cleaner cut.
View CueballRosendaul's profile
CueballRosendaul
484 posts in 2105 days
#2 posted 11-16-2015 04:02 AM
“A lot” of anything and I head to the table saw. Typically for rabbets I put a stacked dado under the edge of a sacrificial fence board. If possible, run the rabbet alongside an entire board and cut lengths needed from the already rabbeted board. Much easier than handling small pieces.
-- Matt CueBall Rosendaul. I don't think I've ever had a cup of coffee that didn't have cat hair or sawdust in it.
View ChuckC's profile
ChuckC
828 posts in 2900 days
#3 posted 11-16-2015 04:17 AM
^ +1
View Jhoppe20's profile
Jhoppe20
3 posts in 889 days
#4 posted 11-16-2015 06:20 AM
+1 on the table saw, much easier for me since I dont have my router set up right now either.
ArtCam
#5 posted 11-16-2015 01:32 PM
Thanks gentlemen.
I’m going to give both a try.
My router is not on a table at the moment.
Appreciate it. Derek
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1141 days
#6 posted 11-16-2015 01:49 PM
However you do it be careful the wood you will be using tends to be narrow so you need safety equipment to prevent an accident. As others have said I would cut the rabbet first and then cross cut, but the entire piece will still be narrow.
View Don Butler's profile
Don Butler
1092 posts in 3360 days
#7 posted 11-16-2015 01:57 PM
If you need narrow pieces, cut the profile on a wider board and then rip it off. You may just save your fingers or at least your nerves.
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
ArtCam
#8 posted 11-16-2015 02:23 PM
WoodNS and Don: my frames are usually about 1by3s or wider as a base and I cross cut the stock on the chop saw first. The frames are usually no bigger then 16×20.
I really appreciate your thoughts about safety. Always the first concern. Thanks guys.
Derek
View bonesbr549's profile
bonesbr549
1531 posts in 3032 days
#9 posted 11-16-2015 03:06 PM
I prefer the router. I either use hold downs or after assembled, use a router with a bit and bearing and a spacer block attached with double sided tape to keep it balanced. I quickly go around the interior, and finish of the corners with a chisel. It makes for a consistent line and is quick. Of course many ways to skin a cat!
https://flic.kr/p/q1tWiZ
