Dust Collection Improvement for a Delta 36-725
Forum topic by nkawtg posted 11-15-2015 06:40 PM 15235 views 6 times favorited 28 replies Add to Favorites Watch
View nkawtg's profile
nkawtg
281 posts in 1452 days
11-15-2015 06:40 PM
Topic tags/keywords: delta 36-725 dust collection tablesaw
The Delta 36-725 is a good saw, and (knock on wood) I haven’t had any of the alignment issues many have spoken of. However it has some shortcomings with respects to dust collection. It is equipped with a blade shroud and 2.5” dust port which for the most part does a good job, but a lot of dust gets past the shroud and drops out the bottom.
So I went to work fabricating a bottom for the machine with a 4” dust port. This is what I came up with:
I used a magnetic duct cover to cover the space left by the removal of the 2.5” dust port.
I added a 4” dust port to the frame below.
Here I fabricated the bottom and incorporated a 4” port from Harbor Freight.
Here is a shot of the pluming under the dust collection pan.
After running some scrap wood through the saw there was virtually no dust on the floor.
It ain’t a pretty solution but it got the job done.
28 replies so far
5176 posts in 2694 days
#1 posted 11-15-2015 06:55 PM
I am very much a “function over form” guy, so who cares what it looks like as long as it works well? Good job…I just wish the tool makers would wake up and put some better DC porting on the tools.
View knotscott's profile
knotscott
8147 posts in 3576 days
#2 posted 11-15-2015 07:07 PM
It looks fine to me…should be a nice performance improvement. What alignment issues has the 36-725 had? I haven’t read of any.
View WhyMe's profile
WhyMe
1073 posts in 1762 days
#3 posted 11-15-2015 07:11 PM
I did the same dust collection mods you did on my 36-725. The comment you made about alignment surprised me because I haven’t heard of that..
nkawtg
#4 posted 11-15-2015 07:25 PM
I stand corrected. It was the Ridged R4512 saw that has the issue.
http://lumberjocks.com/topics/57168
WhyMe
#5 posted 11-15-2015 07:35 PM
I just noticed… is that a Craftsman router top you added? I added my Craftsman router top to the side. I’m starting to see a psychic connection.
I made a more funnel shaped box to get closer to the motor and to direct the dust towards the vacuum hose.
nkawtg
#6 posted 11-15-2015 08:09 PM
Actually it’s a Bosch router table. Perfect fit, though I didn’t like how much it cantilevered out so I moved one of the steel tables to the other side.
View dannorocks's profile
dannorocks
65 posts in 1379 days
#7 posted 11-15-2015 08:56 PM
I’m liking your solution and gives me some ideas. I started on building a cabinet for mine (Delta 36-725) and called it quits during moving out of the house I sold. Once I get some free time here I want to get this saw on the cabinet and haven’t thought of how the 4” dust collection conversion and close up the opening for the 2 1/2”. This seems like a simple solution, but I may do some shop engineering with some 4” PVC pipe and save a little cash.
knotscott
#8 posted 11-15-2015 09:58 PM
- nkawtg
thx for clarifying.
nkawtg
#9 posted 11-16-2015 04:26 PM
WhyMe, after some use, I’ll probably modify mine to be more funnel shaped, dust does tend to settle on the flat pan around the duct.
Now I see how you support the router table, I didn’t spot the diagonal legs before.
What I did was move the left stamped metal table to the other side.
Using an image of your saw, this is what I did.
An advantage to your solution is you can handle wider stock.
WhyMe
#10 posted 11-16-2015 08:30 PM
Believe it or not those diagonal legs are made of black ABS pipe. I was going to do the same as you and move the left wing to the right but I always cut long stock hanging to the left side of the blade, so I kept the left side longer by not moving the wing. I used ABS screw couplings on the ends to adjust the length of the legs to level the router table to the TS table.
nkawtg
#11 posted 11-16-2015 09:26 PM
Very nice.
View Amoc's profile
Amoc
53 posts in 2165 days
#12 posted 11-24-2015 06:18 PM
Excellent, I have had my Saw since January. I have added my router to the right side. I have been having issues with the dust as it grinds into a powder and then when my vacuum pulls it in from the designed port I still have dust all over the place. I really like your ideas, I have been thinking of creating a saw dust box at the bottom with a vacuum port added to pull the dust. I was worried though that not having the factory designed shroud around the blade it may cause other issues, but after seeing yours I cannot see a problem now!
-- Ken from Ft Hood, TX
View hotbyte's profile
hotbyte
991 posts in 3176 days
#13 posted 11-24-2015 07:17 PM
Nice mods on dust collection. I haven’t decided how happy (or not) I am with the dust shroud. Only thing I can compare it to is my old open backed Craftsman 113 contractor saw that had one of those 4” hose plates on the bottom. I never enclosed the back around the belt, motor, etc.. Compared to it, it seems pretty good. I might give this a try using that old adapter to see how it does.
nkawtg
#14 posted 11-24-2015 07:49 PM
Those magnetic vent covers worked really well covering the big holes left by the 2 1/2” dust port at the back and the slot for the blade tilt in the front.
I still may redo the pan to a more funnel shaped affair.
My next project is an old Grizzly band saw I picked up for $100 bucks. No dust collection on it at all.
Hmmm what shall I do…
WhyMe
#15 posted 11-24-2015 08:54 PM
I removed the factory designed shroud around the blade and fabricated a partial shield from sheet metal that still helps to direct the saw dust downward and away from the motor.
showing 1 through 15 of 28 replies
