Quick Sand model 165
Forum topic by roderick posted 11-15-2015 05:23 PM 1254 views 0 times favorited 0 replies Add to Favorites Watch
View roderick's profile
roderick
18 posts in 1800 days
11-15-2015 05:23 PM
This is an ancient 1” x 42” vertical belt sander given to me by a neighbor.I bought new belts. with the belt installed (table removed for clarity) there is about a 3/16 gap along the left edge of the vertical backer plate. There is not enough room to move the drive pulley to the left. With the 3 7/16uts removed from the spring loaded idler assy I can almost got the belt aligned by placing a shim (washer) below the bolts that hold the idler assy to the base assy. I don’t know if I do this will the tracking be a problem? The drive pulley is convex the idler is flat.
Any suggestions? Thanks
-- just doug
0 replies so far
