Tips for crown molding on vaulted ceiling
Forum topic by Dewoof01 posted 11-14-2015 03:49 AM 1401 views 0 times favorited 9 replies Add to Favorites Watch
View Dewoof01's profile
Dewoof01
6 posts in 891 days
11-14-2015 03:49 AM
Hopefully you guys can offer some tips for me. Putting in some crown at my dad’s place tomorrow as woodworking is not his forte. Its prefinished hemlock
. I’ve done crown before and have a kreg jig and angle finder but never on a vaulted ceiling. Here’s some pics to show you a couple of the areas.
9 replies so far
View jerryminer's profile
jerryminer
916 posts in 1408 days
#1 posted 11-14-2015 08:31 AM
For a vaulted ceiling, you will need to either:
1. Cut a transition piece at the corner, or
2. “Cheat” the spring angle on the level wall to match the slope of the ceiling. This would require re-cutting the bottom back bevel.
Check out Gary Katz explanation of the transition
View bonesbr549's profile
bonesbr549
1531 posts in 3033 days
#2 posted 11-14-2015 01:00 PM
Take a piece of scrap and test cut your angles. It will take some time but that will get it perfect.
View dhazelton's profile
dhazelton
2756 posts in 2263 days
#3 posted 11-14-2015 01:37 PM
The runs that go along the angled portion of the ceiling I wouldn’t miter. I’d miter and cope the pieces that run horizontally though. But like said above, your spring angles will probably be slightly different. That’s not a huge angle so I don’t think it’ll be too much different. I hope you have enough scrap for trial and error. I can’t tell what’s going on in that outside corner, if it’s just a straightforard 90 on the same plane….
Dewoof01
6 posts in 891 days
#4 posted 11-14-2015 04:22 PM
Thanks a bunch guys. That Gary Katz page helped. I’ve read his stuff before. Wish me luck I ordered alot of extra as this will be a pain.
MrUnix
6592 posts in 2165 days
#5 posted 11-14-2015 07:31 PM
Get ‘em close, then caulk and paint… only person who will notice it will be you.
runswithscissors
2724 posts in 1991 days
#6 posted 11-14-2015 11:20 PM
Mr Unix has the right idea. My kitchen ceiling was not a perfect plane (didn’t reveal itself until crown molding). Caulk easily filled the gaps, and doesn’t show at all. Much easier than trying to cope the wood to the wonky ceiling, which, by the way, is plaster over metal lath.
View Daruc's profile
Daruc
460 posts in 1099 days
#7 posted 11-15-2015 02:04 AM
It’s a little tougher than that when you’re using “prefinished Hemlock”
Dewoof01
6 posts in 891 days
#8 posted 11-15-2015 03:57 AM
Ya if this wasn’t prefinished wood I wouldn’t have even posted this. The transition pieces gave the best look. Turned out ok for my first time on a vaulted ceiling. Good thing any ugly cuts are 11’ high and not noticable from the ground. My parents as more than happy with the results. Thanks guys. And also the ceiling is sheetrock don’t know why you assme its plaster her metal lath especially since its only a 25 year old home.
Daruc
#9 posted 11-15-2015 04:08 AM
Dewoof01, He was referring to his ceiling being metal lathe and plaster.
Parents are happy, that’s the main thing. Another step towards gaining experience. The next time will turn out even better.
