How to make this edge/profile
Forum topic by Gixxerjoe04 posted 11-13-2015 12:50 AM 658 views 0 times favorited 4 replies Add to Favorites Watch
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1818 days
11-13-2015 12:50 AM
Might be a simple answer but trying to be sure before I make it. My wife was cleaning one of her clients house and found this and wants me to make it for her. Basically a big serving tray/cutting board, it’s 3 feet long so don’t know why there’s a juice groove since I doubt anyone would actually use it as a cutting board. Anyways, the edge of the board and and hole are a lot more rounded and blended into the board a lot more than I’ve ever done so wasn’t sure how to go about it. Was thinking a bigger round over but, the biggest one I’ve used is half inch, so wasn’t sure if that was the actual solution or not.
View mahdee's profile
mahdee
4045 posts in 2009 days
#1 posted 11-13-2015 01:05 AM
I think you should use a small round over. Cut the hole with a hole saw first, then use a round over.
-- earthartandfoods.com
View BurlyBob's profile
BurlyBob
6033 posts in 2507 days
#2 posted 11-13-2015 01:24 AM
Mahdee’s right once again.
View BobAnderton's profile
BobAnderton
284 posts in 3031 days
#3 posted 11-13-2015 01:39 AM
A roundover will get you started but really I’d be achieving part of that shape afterwards with a belt sander for the edges and a sanding drum in a drill for the hole with lots of moving around. If you don’t mind spending a little cash to save some time and maybe be more consistent maybe consider this router bit.
I made a serving board that had that kind of edge and hole profile for my mom out of lacewood 25 years ago using the belt sander method and it turned out nice. I should snap a photo of it next time I visit.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
Gixxerjoe04
#4 posted 11-13-2015 02:52 AM
That bit probably wouldn’t hurt, I just don’t see a small round over bit making that dramatic of a curve around the wood.
