Plank lamination
Forum topic by camin posted 12-23-2009 05:10 AM 808 views 0 times favorited 2 replies Add to Favorites Watch
View camin's profile
camin
10 posts in 3045 days
12-23-2009 05:10 AM
Wow, very impressed with the number of members that welcomed me in such a short time. Many thanks. Also appreciate the reply to question ‘Why maple”. Next question: When laminating planks face to face how should grains be oriented on the planks? ////glue//// or ////glue\\\\ Grains all aligning, or opposing? Planning to use planks on edge, face to face, to make up top of work bench. Know there are 2 schools of thought on edge to edge glue-ups. Can’t find anything on face to face glue-ups
2 replies so far
View NathanAllen's profile
NathanAllen
376 posts in 3111 days
#1 posted 12-23-2009 07:27 PM
Same rules for face to face, you can easily get away with /// to ///, since the width of the glue-up will be longer than a 3/4 edge to edge. Mostly you’d use same orientation on a tabletop if you’re also using a beadboard.
Since grain orientation won’t be as obvious, ///glue\\\ is better since it will offer a stronger bond and minimize movement during the glue up.
camin
#2 posted 12-24-2009 05:07 AM
I like the sound of better inherent stability of lay-up with opposing grain, /// to\\\. I used this technique in buliding up frame for workbench. What troulbes me is that I ran into tear-out problems when planing and scraping. Considering I’m going to go to alot of effort to get the top flat I’m reluctant to sign-on to more problems than necessary.
