Suede Tex undercoat adhesive stained project
Forum topic by Bret posted 12-22-2009 11:43 PM 1360 views 0 times favorited 3 replies Add to Favorites Watch
View Bret's profile
Bret
166 posts in 3547 days
12-22-2009 11:43 PM
Topic tags/keywords: question
I was applying suede tex undercoat adhesive to the inside of a box I’ve been building and dripped a little bit. Unfortunately, when I went to wipe up the adhesive, it spread and appears to have stained the area where it was with a faint reddish color (the adhesive is wine colored). I suspect I’m going to have to sand down and re-finish these spots (there are several). The underlying wood is curly maple finished with a tinted shellac and four coats of seal-a-cell. Does this seem like the right approach?
I’m willing to take the heat for this—the varnish was dry to the touch but may not have been fully cured when I tried this….
-- Woodworking is easy as 3.14159265358979323846264338327950288419716939937510...
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3765 days
#1 posted 01-20-2010 05:35 AM
How did the repair go? Does it look okay?
View Bret's profile
Bret
#2 posted 01-20-2010 05:22 PM
It came out fine—some light sanding removed the stain lickety-split. The completed project is here. Thanks for asking—I completely forgot to close out this post.
Mark Shymanski
#3 posted 01-20-2010 05:39 PM
It is a good looking box, glad the stain was easily removed.
