Kitchen farm table progressing
Forum topic by MashMaster posted 11-12-2015 03:56 AM 696 views 0 times favorited 9 replies Add to Favorites Watch
View MashMaster's profile
MashMaster
134 posts in 2801 days
11-12-2015 03:56 AM
I have finally moved beyond milling the wood for my kitchen table. I have the outside frame now dry fitted but I know I need to put in one or two support crossbars. I’m a bit stumped about the best way to add them. Maybe face glue supports on the inside of the frame and support cross beams. like a 3×1x4 piece with a notch cut out to support the cross bar. And face glue that to the inner frame. That make sense? any suggestions for a better plan?
The frame is about 3’ x 6’
-- - Dave ; Austin, TX
9 replies so far
View bonesbr549's profile
bonesbr549
1576 posts in 3208 days
#1 posted 11-12-2015 02:44 PM
Well if you don’t want outward visibility on the outside of the table apron, I’d do sliding dovetail or stopped sliding dovetail.
If thats not a big deal, a method I use is to use a mortise chisel, on a 45 angle to create a diamond and then screw it to the sides and plug the hole with a contrasting wood. It makes a nice design feature.
There are many ways to skin that cat.
View JeremiahD's profile
JeremiahD
5 posts in 1078 days
#2 posted 11-12-2015 03:38 PM
Wow. That’s nice looking already. I just hand planed my walnut tabletop. Looking at starting the base tonight. Mine is 2.5×4ft, due to small living conditions. Spend all my money on wood and tools, not sqft in my apartment! Ha.
JeremiahD
#3 posted 11-12-2015 03:39 PM
I’m now just trying to decide how/what I want to do for base. Prob legs won’t be as sexy as yours.
View rwe2156's profile
rwe2156
3087 posts in 1622 days
#4 posted 11-12-2015 03:43 PM
What bones said.
If you’re not opposed, even a simple L bracket will work.
View jdh122's profile
jdh122
1038 posts in 2959 days
#5 posted 11-12-2015 03:57 PM
I’ve generally used dowels for that joint. Generally for joinery I prefer to use other joints than dowels, but they’re perfect for this application, I think.
I think one cross support will be enough.
-- Jeremy, in the Acadian forests
MashMaster
#6 posted 11-12-2015 04:43 PM
Thanks for the compliments. I can’t take credit for the legs though, I purchased them through mail order because I don’t have a lathe.
I like the idea of the stopped sliding dovetails, it does make me a bit nervous since I have never done them before so I may chicken out and do dowels.
How hard is it to do a sliding dovetail in the middle of a long board?
I was thinking is 2 cross bars, one every 2 feet.
bonesbr549
#7 posted 11-12-2015 05:10 PM
Thanks for the compliments. I can t take credit for the legs though, I purchased them through mail order because I don t have a lathe.
- MashMaster
Dive in, get some cheap poplar to practice on. If you have a router table cut the dovetail in the side first. Then put the dovetail bit in your table and take a pass against one side of the crossmember, and flip it and do the other side. Keep exposing a tiny bit of the bit and repeat proceedure. Test fit and once its snug your there. I’ve got the incra fence so i can adjust my fence by the thou. As Charles Neil says “sneak up on it”
Practice on some poplar then do the real thing. TNT (TaintNuttinToit)
MashMaster
#8 posted 11-13-2015 01:49 PM
Questions:
  • If I go with the sliding dovetails, how deep should I go? The apron is 1” thick, so I was thinking 3/8”
  • How much will that weaken the apron?
  • Should I make 45 degree angle pieces in each corner connected to the adjacent aprons to help for support and maintain the 90 degree angles?
MashMaster
#9 posted 11-15-2015 08:28 PM
Questions:
