Jointer Not Leaving a Smooth Surface
Forum topic by stidrvr posted 11-12-2015 02:16 AM 986 views 0 times favorited 11 replies Add to Favorites Watch
View stidrvr's profile
stidrvr
31 posts in 3349 days
11-12-2015 02:16 AM
Hey all,
I bought an 8” jointer about 5 months ago. I haven’t had a whole lot of time to use it until recently when I started a bathroom vanity project. Im surfacing White Oak and its leaving a rippled finish. Its like chatter, I can kind of feel it when Im surfacing but Im not sure if this is normal or not. The guy that had it before me put a new set of blades in and they’re super sharp! I believe I have the tables set correctly as I had to remove them to get it downstairs. I don’t have a picture of the surface so thats about the best as I can describe it. Any Ideas on what to check? I tried different feed speeds, and it doesn’t seem to matter with depth of cut.
Thanks in advance.
11 replies so far
View jmartel's profile
jmartel
7633 posts in 2024 days
#1 posted 11-12-2015 02:17 AM
Most likely one of the blades is higher than the others.
MrUnix
6193 posts in 2073 days
#2 posted 11-12-2015 02:19 AM
+1 to the above ^^^^
Sounds like the guy you bought it from just threw in some new blades so he could sell the machine, and didn’t take his time to set them properly.
View Pezking7p's profile
Pezking7p
3217 posts in 1526 days
#3 posted 11-12-2015 02:54 AM
Just move the wood slower. It’ll come out smooth as glass.
-- -Dan
View TheFridge's profile
TheFridge
8669 posts in 1360 days
#4 posted 11-12-2015 03:02 AM
Slower will work but the highest blade will dull quickly and way before the rest.
Sounds like a good time to learn jointer setup.
Pezking7p
#5 posted 11-12-2015 03:05 AM
Ok. I guess I was assuming that the jounter was set up. If one blade was higher than the rest it wouldn’t cut a flat surface in any case.
-- -Dan
View iminmyshop's profile
iminmyshop
284 posts in 1868 days
#6 posted 11-12-2015 03:13 AM
Second the running the wood through slower before messing with the blade alignment. Really slow.
-- http://www.alansfinewoodworking.com/
View CB_Cohick's profile
CB_Cohick
483 posts in 1125 days
#7 posted 11-12-2015 01:15 PM
I was having the same trouble edge jointing some maple recently, and found that slower was the sauce, as mentioned by multiple others above. In addition, less downward force when feeding the boards through seemed to help also.
-- Chris - Would work, but I'm too busy reading about woodwork.
View teejk02's profile
teejk02
479 posts in 999 days
#8 posted 11-12-2015 02:18 PM
Pay attention to the direction of the grain also. Sometimes it’s hard to see until after a pass or two. And years ago I set my 6” jointer to only take very shallow cuts and I leave it there…more passes of course but works for me.
View rwe2156's profile
rwe2156
2749 posts in 1355 days
#9 posted 11-12-2015 02:37 PM
The knives are not set correctly.
You fix that by resetting the blades, not feeding the work slower.
You will need a knife setting jig or a dial indicator referenced off the table (my preference).
I try to get mine dead on but no more than .002.
Yes, feeding the work slower will improve the surface, even with properly set blades.
I always hit it with a hand plane or scraper anyway, so I’m not looking for a glass smooth surface right off the machine.
After you do that, I would check the tables for parallelism.
stidrvr
#10 posted 11-12-2015 11:42 PM
OK, thanks guys. Ill check the blade heights.
View hhhopks's profile
hhhopks
650 posts in 2251 days
#11 posted 11-13-2015 12:49 AM
+1 on touching up with a hand plane.
-- I'll be a woodworker when I grow up. HHHOPKS
