Advice on Glue ups for irregular designs
Forum topic by TheGreatJon posted 11-11-2015 10:34 PM 781 views 0 times favorited 5 replies Add to Favorites Watch
View TheGreatJon's profile
TheGreatJon
340 posts in 1475 days
11-11-2015 10:34 PM
My sister asked me to make her a serving tray and together we came up with a cool design for the base. I had to glue the herringbone pattern onto a plywood base to make the glueup possible. But then when my wife saw the pattern, she loved it and asked me to make her a cutting board with the same design.
Now I am struggling to figure out how on earth I can make a cutting board with that design when I will have to clamp up all of those individual pieces. Its not like I could clamp them in rows like I would with a normal linear cutting board design. Does anyone have any suggestions on how to glue up with this type of design without using a base?
-- This is not the signature line you are looking for.
5 replies so far
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1257 posts in 1955 days
#1 posted 11-11-2015 10:49 PM
Hmm.. Perhaps glueing onto a scrap pieze of wood and cut it off afterwards?
-- "Do or Do not. There is no try." - Yoda
MrUnix
7117 posts in 2441 days
#2 posted 11-11-2015 10:50 PM
I would glue them all up, then put 4 pieces of scrap (one on each side) for the clamps. Use parchment paper to keep things from sticking to the scrap wood and/or whatever you are doing the glue-up on.
Hmmm… I forgot that the initial glue up won’t have those nice straight edges on the sides… where is the ‘delete post’ button when you really need it :)
View AandCstyle's profile
AandCstyle
3185 posts in 2499 days
#3 posted 11-12-2015 12:08 AM
John, make two “M” shaped jigs with the legs of each at 90 degrees where the inside of each is the shape of the letter and the outside is solid across. Fit the pieces into the jig on a non-stick surface and clamp with the beams of the clamps on the outside edges to contain the individual pieces. Cut this to square after the glue has cured overnight. I’m sorry if this isn’t clear, but ask any questions you may have.
-- Art
View Woodknack's profile
Woodknack
12469 posts in 2622 days
#4 posted 11-12-2015 12:18 AM
Make a glue up jig from melamine with the starting end to fit the irregular shape.
TheGreatJon
#5 posted 11-12-2015 04:53 AM
John, make two “M” shaped jigs with the legs of each at 90 degrees.
- AandCstyle
- Rick M.
Right, I’ll give it a shot. Thanks guys!
