Need advice circle routing jigs
Forum topic by groland posted 12-22-2009 07:02 PM 1855 views 0 times favorited 3 replies Add to Favorites Watch
View groland's profile
groland
187 posts in 3498 days
12-22-2009 07:02 PM
I am repairing a vintage audio turntable (a Thorens TD-124 for those of you who are audio buffs.). In order to do this, I need to be able to route perfect circles from about 1 inch in diameter to about 12 inches in diameter in 3/4 MDF.
I am thinking there must be some sort of precision router jig available for this purpose. If not, what kinds of jigs might I make and how best to make them?
Essentially, I need to route/cut the MDF into a perfect circle ca. 12” in diameter. Then I need to route two depressions in it, both perfectly centered, one about 1.5 inches in diameter around the center and the other about 1/8 width about 6 inches from the center.
Any suggestions?
Many thanks,
George Roland
3 replies so far
View CoolDavion's profile
CoolDavion
434 posts in 3911 days
#1 posted 01-16-2010 09:40 PM
Don’t know if you found what you were looking for yet but for purchase
http://www.hartvilletool.com/sphider/search.php?results=10&search=1&query=circle%20jig I’ve also seen plans for creating your own somewhere.
-- Do or do not, there is no try!
View davidpettinger's profile
davidpettinger
661 posts in 3287 days
#2 posted 01-16-2010 11:02 PM
These guys should be able to cover any options you may require.
http://www.jaspertools.com/
-- Methods are many,Principles are few.Methods change often,Principles never do.
View romanf's profile
romanf
20 posts in 3342 days
#3 posted 01-18-2010 06:40 PM
I have used the Jasper circle cutters and can say they work extremely well and are of high quality….
