Drop leaf table
Forum topic by redtail posted 11-11-2015 09:04 PM 680 views 0 times favorited 3 replies Add to Favorites Watch
View redtail's profile
redtail
48 posts in 1120 days
11-11-2015 09:04 PM
I have completed the build on a shaker style cherry drop leaf table. I am almost done with surface prep but I am not sure of how to go about finishing the top. Specifically, should I break the top down into it’s components or finish it with the hinges attached? What are the pluses and minuses for each approach? My plan is to use Waterlox original.
3 replies so far
View HokieKen's profile
HokieKen
4985 posts in 1134 days
#1 posted 11-11-2015 09:21 PM
I prefer to break things down whenever possible for finishing. That way I get all the cracks and crevices and don’t get oil/stain on the hardware. Obviously joinery stays in tact but if it’s a simple matter of removing a screw, I’ll do it.
-- Kenny, SW VA, Go Hokies!!!
View ChefHDAN's profile
ChefHDAN
1062 posts in 2845 days
#2 posted 11-11-2015 10:54 PM
Red Tail I recently refinished a drop leaf table and completely disassembled the top because I could never hope to turn it over if it was in one piece.
Click for details
I would have to say that if it was all together you would run a great risk of getting finish between the cracks on the edges and be unable to brush them out if you tried to do it as one piece. Note mark the mortises when you remove the screws and hinges, I learned that both sides were not the same on mine.
redtail
#3 posted 12-23-2015 04:43 PM
Thanks for the input. Here is the finished table:
http://lumberjocks.com/projects/208122
