Friends,
I've given up on chamfering using an old (and cheap- long ago) 45 degree chamfer bit. It burns despite being cleaned and the bearing lubricated. I use it to soften the edges of tabletops, legs, etc because I can't get a uniform chamfer using a block plane.
So, I'd like to get a new chamfer bit but I have trouble deciding: should I get a 1/4" bit and use it in my little DeWalt trim router - and take advantage of the easy handling, etc? Or a 1/2" shank bit so I could use it freehand as well as in my 2 hp Porter Cable router - thereby allowing use in the router table?
Lastly - which brand: Rockler? Freud? Infinity? CMT?
It depends on how much your "softening" the edge. If it's a light cut just to get rid of the sharp corner, a 1/4" shank should be fine. Of course, 1/2" shank will never hurt anything and is recommended if you're taking substantial cuts. If you want a single bit, go with the 1/2" so you can use it for most anything.
I've developed a liking for Yonico bits. Amazon has this set at a great price. If you just want the 45, they have it too. If you're using this hard and often, go with the whiteside waho recommended above. If you just use it on occasion, the Yonico is a solid choice at a fraction of the cost.
Mike, I now do almost all my chamfers with a hand plane.
The big advantage is you will always be able to go with the grain to eliminate tear out (can't do that with a router). As a result, you will get a much cleaner, sharper surface that I think looks better.
Plus, its quieter, dustless, eye protection-less, no fiddling, no burning, no tearout (did I say no tear out?).
Lastly, its downright therapeutic (especially when pausing to sip an ice cold Heineken)!!
You know, as I was writing the question, I thought "some LJers will suggest hand planing." But I'm not so confident with my block plane. Perhaps my low angle jack? Better control and more comfortable two-handed operation?
Thanks all for responses…keep em coming, please
I use a L.N. Brass 102 usually but just picked up the L.V. Apron plane with the PMV-11 blade, these blades stay sharp forever! Anytime I use a router it is always a Ryobi cordless trimmer with a Freud 1/4" shank round over bit, no cord can get almost everywhere and more than enough power for taking the sharp edges of.
I really like my little Dewalt router, and for an edge bit that might get used more often taking the tool to the wood as opposed to taking the wood to the router, I'd go with the 1/4" as was said above chamfer does not really take a lot of load to the bit. Of course I've also got an adapter for my 3hp PC to run the 1/4" so it be a no worries purchase.
For light work using small bits I reach for my little Dewalt way more often than a bigger router. It's super light weight and the LED light is a feature I have no idea why it isn't included in bigger models. The key is light duty tasks like small 1/4" round overs are perfect for this router.
Don't you have a 1/4" collet for your router table router?
As for brand I have been very happy with Whiteside of late.
I do have a 1/4 to 1/2 collet for the big router; I just worry that the 1/4 bit isn't as stable as the 1/2 bit
My latest project was a coffee table with an elliptical top of about 54" in length, so I would rather take the router to the work as opposed to the converse - so the small router worked better - Like Richard H Question for RWE2156 - what style of handplane do you use when knocking off edges? block? big/little? How to you keep a consistent angle (I know…practice, practice…) Nobody seems to disagree with Whiteside for quality…
The big advantage is you will always be able to go with the grain to eliminate tear out (can t do that with a router). As a result, you will get a much cleaner, sharper surface that I think looks better.
C'mon rwe, you're setting a bad example for the noobs. Safety, safety, safety.. LOL
bigmig, a router that you can handle easier is much better for chamfering as long as it's a light cut. Trim routers were designed for mostly laminate work, trimming laminate at possibly .060" at the most. Back cutting first and then cutting the forward direction will eliminate most tear out.
If ya cain't plug it in, it ain't worth usin. hehe…...... Jerry (in Tucson)
My opinion is it's hard to beat the older Stanley 60 1/2 block planes. It's well sized for those kinds of light duty work, the low angle excels at cutting the end grain part of the round over and it's light weight makes it easy to use for extended amounts of time. Lie Nielsen has a very nice reproduction but I have used it at shows a few times and always came away feeling like it was a bit heavy and bulkier than the old Stanleys.
As for technique it is practice but a couple things that might help. You can put pencil marks as references on both faces to give you a guide to follow than aim just short of those rotating the plane over the edge making smaller and smaller facets as you go. The plane can't cut a curve only progressively finer flats that at some point resemble a curve. Also don't sweat it to much. Get it close than a light pass with sandpaper or a scraper evens it all out.
I love small routers for small chamfering and roundovers… I keep an older Bosch trim router dedicated to a small roundover for shop appliances. This is a great use for older laminate trimmers and cheapies, like Grizzly or HF trimmers. You don't need, or even want, a 1/2" router for a 1/16" or 1/8" roundover or chamfer.
I like Whiteside, CMT, Freud, pretty much all the same in this class. For big bits, Whiteside is my first choice, but here it's less important, as long as you stick with the better brands.
BTW… I have many, many, hand planes and love to use them, but suggesting hand planes to a guy specifically asking about router bits is kind of lame…
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
