Seamless Face Frames?
« back to Joinery forum
Forum topic by Scott posted 11-11-2015 07:15 PM 722 views 0 times favorited 4 replies Add to Favorites Watch
View Scott's profile
Scott
110 posts in 1229 days
11-11-2015 07:15 PM
I’m working on a few cabinets that are face framed with raisRd panel doors. I have a pocket hole jig which is what I used to join the face frames. However, they are not perfectly flat. I clamped the two ends together when I assembled them, but they didn’t assemble perfectly flat. What would be the best way to flatten them for a seamless look? Sanding would take a lot of time so I’m thinking a card scraper or hand plane?
View pintodeluxe's profile
pintodeluxe
5544 posts in 2686 days
#1 posted 11-11-2015 07:20 PM
Sanding with a random orbit sander and 100 grit paper will take care of that in a hurry. I am assuming the shift is 1/32” or so. A hand plane will cause you headache where the grain changes directions. A card scraper I fear would take too long (good for smoothing but not much more).
In the future you may want to clamp both the rail and stile to a flat workbench before running in the screws.
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2243 days
#2 posted 11-11-2015 07:26 PM
How far off are they? I’ve used the ROS like Willie said, and it works fine. I had one instance where it was a bit more off, I used a smoothing plane cross-grain on the ends of a stile to get it close, then use the ROS to finish it off, but that can be risky depending on the wood type and grain direction.
View rwe2156's profile
rwe2156
2749 posts in 1354 days
#3 posted 11-12-2015 01:01 AM
No question about it: hand plane.
All that dust…....oy
Watch that grain direction!
View josephf's profile
josephf
173 posts in 1970 days
#4 posted 11-12-2015 01:39 AM
I got one of those big steel plates http://www.amazon.com/Kreg-KKS-KLBKSYS-Heavy-Duty-Bench-System/dp/B001DCEN3O/ref=sr_1_fkmr1_2?s=hi&ie=UTF8&qid=1447292139&sr=1-2-fkmr1&keywords=craig+jig+bench+clamp . mounted it into a solid core door .this was an improvement . have you tried adding a biscuit for allignment . I think the most important thing is to take the time to set-up .Seems like it hasn’t been a problem like when I first stared using pocket screws .
