Matching cabinet problem
Forum topic by Tipsy posted 11-11-2015 12:44 PM 592 views 0 times favorited 7 replies Add to Favorites Watch
View Tipsy's profile
Tipsy
2 posts in 954 days
11-11-2015 12:44 PM
Topic tags/keywords: cabinet custom
I would like to order two 36” bathroom vanities from a custom company through Menards called Briarwood. However, I would like to have a 24” cabinet between the two vanities that would have a pullout laundry basket. Briarwood doesn’t seem to offer this type of cabinet. Contacted a local cabinet company to see if they could make a custom cabinet that matches the vanities and they couldn’t make it work. Going custom for all pieces is over extending the budget. Any suggestions?
7 replies so far
View bondogaposis's profile (online now)
bondogaposis
4767 posts in 2378 days
#1 posted 11-11-2015 12:57 PM
Make the whole thing yourself.
-- Bondo Gaposis
View rwe2156's profile
rwe2156
2965 posts in 1507 days
#2 posted 11-11-2015 01:16 PM
If its similar to a trash can pullout, you can remove the door on any standard base unit and install the hardware.
View ShaneA's profile
ShaneA
6956 posts in 2625 days
#3 posted 11-11-2015 03:22 PM
Yep, I would vote to buy a 24” base, then modify to meet your needs. That way the finish is a match.
View Knothead62's profile
Knothead62
2584 posts in 2987 days
#4 posted 11-11-2015 08:53 PM
Check with Lowe’s, they should have the aftermarket hardware for a pullout.
Tipsy
2 posts in 954 days
#5 posted 11-12-2015 03:51 AM
Thanks for all your help! I have attached a link to the type of cabinet I am thinking of using. So it is possible to just pull off the drawer fronts and somehow reattach them as one piece with one large deep pull out drawer (laundry hamper)? I understand inserting the drawer hardware but don’t understand how the front can be done.
If you haven’t figured this out yet, I am in no way a woodworker and will probably need to hire someone. Any advice on how to find a good person to do the work? Any local associations I can contact or is Angie’s List the way to go? I’m in MN.
http://www.menards.com/main/p-1444425328679.htm
Thanks!
View waho6o9's profile (online now)
waho6o9
8207 posts in 2603 days
#6 posted 11-12-2015 03:57 AM
Excellent advice above, buy the cabinet and modify it, good call
View jerryminer's profile
jerryminer
928 posts in 1468 days
#7 posted 11-12-2015 04:21 AM
You can simply add a piece of plywood behind the drawer fronts to tie them together and attach the pull-out hardware to that.
