Stanley No. 98
« back to Hand Tools forum
Forum topic by PaulHWood posted 11-10-2015 01:36 PM 868 views 0 times favorited 8 replies Add to Favorites Watch
View PaulHWood's profile
PaulHWood
432 posts in 2220 days
11-10-2015 01:36 PM
Topic tags/keywords: planes restoration
Anyone with good ideas for getting the screw out. It was partially stripped when I got it. I have saturated with WD 40 and another penetrating oil to no avail. Even tried heat.
Thinking I will have to tap it and ruin the screw in which case I would need a replacement screw
Any ideas would be appreciated.
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
8 replies so far
View chrisstef's profile
chrisstef
17311 posts in 2974 days
#1 posted 11-10-2015 01:40 PM
A mixture of acetone and ATF (transmission fluid) is supposed to be the best out there.
View rwe2156's profile
rwe2156
2883 posts in 1448 days
#2 posted 11-10-2015 01:57 PM
My wife restores antique sewing machines and frequently comes across this problem.
I have successfully gotten stubborn screws out with an impact tool like this.
You have to be very careful not to bugger the screw head by securing the plane in a clamp, etc.
I know Singer sewing machines have a proprietary screw thread and maybe Stanley, too.
Before drilling out I would check to see if Stanley screws are a proprietary thread pitch/diameter if so, you’ll have an issue finding a correct tap.
Good luck.
View Bill White's profile
Bill White
4907 posts in 3928 days
#3 posted 11-10-2015 03:05 PM
Highland Woodworking in Atlanta has a kit with Stanley replacement screws, etc.
Bill
-- bill@magraphics.us
View HokieKen's profile
HokieKen
4747 posts in 1106 days
#4 posted 11-10-2015 03:24 PM
Try sticking it in the freezer for a few hours. Brass will contract much more than steel with a drop in temperature. It may or may not work in this case, but it’s definitely worth a shot.
-- Kenny, SW VA, Go Hokies!!!
View Johnny7's profile
Johnny7
361 posts in 1058 days
#5 posted 11-10-2015 04:08 PM
Which Stanley 98 are we talking about?
there is both a side rabbet plane and a marking gauge with that number
PaulHWood
#6 posted 11-10-2015 05:34 PM
Side Rabbet plane
- Johnny7
View theoldfart's profile
theoldfart
9619 posts in 2419 days
#7 posted 11-10-2015 05:43 PM
I had a 98 or 99, don’t remember which one I have both, with a stuck screw on the nose piece. I let it soak overnight in a 50/50 solution of ATF and acetone. It came out the next day no problem. I also freed up a frozen hollow tenon auger that was frozen solid, it took two days. The stuff works. You do have to agitate it often for it to work.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Johnny7
#8 posted 11-10-2015 09:27 PM
^I’m with Kevin on this one—
I would only add that patience is the key—there’s no need to force anything.
I’ve rehabbed many a tool in my time and have never once broken or snapped anything off.
