I have seen lots of posts on here recently where hungry minds are looking for finishing advice on the best ways to apply and finish using lacquer. There are always lots of good tips and techniques presented, but it seems no one ever mentions the first step necessary to achieve desirable results. If you are going to use lacquer, start with a sanding sealer. First off it seals the wood pores and sets you up with a nice surface to build on and second it allows the actual lacquer to go farther. You shouldn't paint unless you prime and you shouldn't lacquer unless you seal.
I agree to a point. I do use sanding sealer for most of my lacquer work. It is much easier to sand and does what the name says--it seals, therefore it takes less lacquer to finish the job.
However, I don't use it for things like my guitars. I believe you get a tougher finish without the sealer. I guess I don't have any scientific backing for that, but it has worked well for me. Guitars don't have that much surface, so the sanding and extra coats are not an issue with me. I would be interested to know if anyone else ever does this.
I respectfully disagree.Sanding sealer just has some additives to make it sand better.I dont think it seals any better than a first coat of lacquer.If I need to seal in a previous finish I will seal with dewaxed shellac before the first lacquer coat
Sanding sealer has inert fillers in it that will help fill the voids in the suface at the same time masking the grain to some extent. You must be familair with the type of filler you choose so as to max of minimise the opaquig effect.
If you seal with a .5lb cut of dewaxed shellac and then do a light final wet sand with alcohol and a high grit, the effect is the same as sanding sealer but no worry about any fillers because what fills the pores and voids is a mixture of wood and shellac residue. This is great on red oak if you are trying to minimize the open grain but not totally eliminate it.
There's a pretty good article here that deals with the zinc stearate additive found in many lacquer based sanding sealers.
As a matter of fact the entire article is a good read if you have problems with finishing.
I agree and disagree…............depends on the mfg of the lacquer. I presently, and for the last 7 years have used a pre cat lacquer that requires ZERO sealer and the first coat of lacquer sands like a dream. They do sell a sealer but why stock both at 200 bucks a pail with a 3 month shelf life.
Having said that…......there re many mfg's of lacquer that do recommend a sealer coat. I'm not postive if its mandatory or if its just a way to get you to spend more money.
There seems to be some confusion between a sanding coat and a sealing coat here.
Apparently they are both used for different specific purposes.
"Sanding sealer is a specific material developed for the lacquer industry, but somehow the name has spread to things that should, by rights, simply be called sealer. For instance, the Zinsser SealCoat label calls it sanding sealer when it is really straight sealer. "
It's my opinion only…...........sealer is old school. I visit a lot of shops that dothis for a living having worked for them, sub contracted for them, but I sure know a lot of folks who do this for a living and withonly one exception…..............none of them use sealer. I'm not saying that using a sealer is a bad idea, just saying that it's old school.
i use lacquer almost exclusively and have to say the only time i use a seal coat is if i plan to use a toner or die to get and even color or if i am going to use a pore filler. any other time i have found it to be a wast of time. in the time it takes me to put on a sealer and let it cure i can have i don't know 100 coats a lacquer on the piece. the main reason for using lacquer is the speed of application and it rubs out like no other finish.
I know that Bob Flexner is not a big fan of sanding sealer.He also prefers using a first coat of lacquer to seal unless you need a barrier coat in which case he uses shellac.
The science of lacquer and other coatings is intense. I am fortunate to have experience in what can go seriously wrong, at the expense of former "bosses" where entire kitchens had to be thrown out/garbage because of simple errors made during applications.
I willadmit that some hand applied finishes knock the socks off of lacquer but like others have said, lacquer is fast, durable, and relatively simple to apply…..........too bad the equipment is so expensive
Like I said Bob…............the only shop that I know of, thats using sealer has to use it, because thats how the mfg (ILVA) recommends and its also a post cat sealer with post cat lacquer.
Most shops use pre cat lacquer…...........no sealer.
The amount of coats required might be more determined by the system it is applied with. An "air assisted HVLP" produces very little overspray, so most of it is on the board, not in the air there for less coats. My rule is to apply as many coats as needed to produce the finsih required.
I also like the post cat lacquers and occasionally use them as its the only product that meets specifications but for me, post cat is not very cost effective. All lacquers are not created equally.
Overall…..............I'ld say to use what works for the individual.
My original post was more aimed at first time users. If a LJ is asking about finishing, chances are they don't know ways around certain methods. That being said, I have opposite experience from you Roman in that I have never met any outfit that does not use a first coat sealer. Overall finish and cost are my motivators. Sealers are cheaper than lacquers. My standard finish schedule for cabinetry is one coat vinyl sealer and two coats pre-cat lacquer. It would cost me approx 17% more in finish materials, per project, to use only lacquer. Nickels and dimes add up over the course of a year, especially when you need quarters to keep the doors open.
747DVR, mea culpa. too early in the morning for me . I shovleld off the driveway and came back in to make this stupid error . Sorry
Barry, I am like you , know most of it by experience but it's often difficult to duplicate the finese of a well written article in 30 seconds or less on a wood forum. <g>
I don't think that rhett was trying to start a debate. He was simply trying to help newbies achieve success without ruining something that they have probably spent countless hours on. Thanks for the info rhett, I personally found your info to be very useful. Happy Holidays!
I dont think there is really much of a debate.There are many different ways to get a great finish on a project.As long as the final finish comes out well no one can tell you that you did it wrong.I think that if you put 3 lacquered boards together,one sealed with sanding sealer,one with shellac and one without sealer you would be hard pressed to tell the difference.If it works for you stick with it.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
