Staining oak
« back to LumberJocks.com Site Feedback forum
Forum topic by bill48 posted 12-21-2009 05:27 PM 1204 views 0 times favorited 8 replies Add to Favorites Watch
View bill48's profile
bill48
9 posts in 3054 days
12-21-2009 05:27 PM
I am completing a project that calls for oak plywood edged with solid oak. I know the edging is red oak and the plywood looks like it may be white oak. I need some suggestions for staining, hopefully, so that both types of wood look relatively even. Help, please.
8 replies so far
View GMman's profile
GMman
3902 posts in 3568 days
#1 posted 12-21-2009 06:57 PM
Try it 1st on left over pieces.
View poopiekat's profile
poopiekat
4322 posts in 3605 days
#2 posted 12-21-2009 07:19 PM
bill48,
check out my roll top desk in my projects. It was made from a combination of oak veneered plywood, miscellaneous species of oak, and commercially made oak bullnose. The oak lumber came from perhaps a dozen different sources. Though the camera picked up a few different hues, in person the desk all matches quite well, with nothing more than Minwax Red Oak stain and a few sanded coats of clear gloss polyurethane. It’s more a challenge of matching boards all cut the same way on the saw, quarter-sawn oak tends to absorb stain differently than flat-sawn in my opinion, but staining does tend to even out the variations in wood color.
bill48
#3 posted 12-21-2009 09:31 PM
You wouldn’t suggest a sealer first?
poopiekat
#4 posted 12-21-2009 11:33 PM
I never use sealer on oak, bill48! Although sometimes I’ll fill the pores first with one of those heavy-bodied products, but it makes the adsorption into the pores a bit uneven. I ‘ll use it only when there is a need for an absolute glassy surface. On birch, maple or cherry, yes, a sealer is mandatory due to the blotchyness that sometimes results.
bill48
#5 posted 12-21-2009 11:35 PM
Thanks much for your help.
bill48
27251 posts in 3693 days
#6 posted 12-22-2009 05:25 AM
Bill, I agree with poopiekat. Oak takes stain well so a sealer is not necessary. I generally use a sealer after the stain has cured. For a sealer I generally use 1# shellac over oil base stains. Otherwise the stain may bleed into the topcoat.
I seal only raw woods such as birch, pine and poplar which will blotch badly if not sealed prior to staining.
bill48
#7 posted 12-22-2009 07:35 PM
I appreciate all of the input and replys.
bill48
View NathanAllen's profile
NathanAllen
376 posts in 3015 days
#8 posted 12-23-2009 12:20 AM
Oak is extremely easy to stain, but the plywood will accept less color, so perfectly matching the solid and the ply will present a small challenge.
Work the plywood section to the color density you want first then work on the solid. Whether you use tape or have a very steady hand it shouldn’t matter, there is a lot of margin for error, just something to be a little careful about.
