Can I use a shop vac with my table saw?
Forum topic by DTrak posted 11-09-2015 01:34 PM 4450 views 0 times favorited 24 replies Add to Favorites Watch
View DTrak's profile
DTrak
58 posts in 1063 days
11-09-2015 01:34 PM
I have cabinet maker grade Sawstop table saw with a 4” dust collection port. I also have a shop vac with a 1 1/4” hose. I havent used the table saw yet. Two questions:
-Can my shop vac handle the output from the table saw, or do I need to buy something else?
-If yes, what is the best way to go from 4” to 1 1/4” hose? I have only seen adapter that go down to 2 1/4”.
thanks
Dan
24 replies so far
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1142 days
#1 posted 11-09-2015 01:46 PM
I have never tried to do what you are asking, but my thought is that the shop vac will not have enough power to adequately move the chips. It will get some but not as many as a dust collector will.
The items to consider is suction measured in static pressure and amount of air moved measured in cfm (cubic feet per minute).
Many hobbyists buy the Harbor Freight dust collector. It regularly goes on sale for around $160 then there are 20% off coupons that reduce it even more.
View johnstoneb's profile
johnstoneb
2868 posts in 2138 days
#2 posted 11-09-2015 02:41 PM
Your vac will pull the sawdust off your saw just fine. You just need to get down to you vac hose.
-- Bruce, Boise, ID
View Bill White's profile
Bill White
4903 posts in 3926 days
#3 posted 11-09-2015 02:57 PM
Reducers are readily available. I bought one a HD (shudder).
Bill
-- bill@magraphics.us
View waho6o9's profile (online now)
waho6o9
8164 posts in 2542 days
#4 posted 11-09-2015 03:05 PM
View builtinbkyn's profile
builtinbkyn
2200 posts in 906 days
#5 posted 11-09-2015 03:10 PM
I plan on doing the same, however I think a 2 1/2” hose is needed along with a shop vac that has a rating of 5+ HP and the highest CFM you can find. A separator will also help. I used a Ridgid 16g shop vac attached to the dust port on a Bosch 4100 and it certainly made a difference. However I didn’t have a separator attached, which I think will further improve the performance. So I wouldn’t reduce the size of the collection hose.
-- Bill, Yo!......in Brooklyn & Steel City :)
View Knothead62's profile
Knothead62
2584 posts in 2926 days
#6 posted 11-09-2015 03:52 PM
I have a DD on my TS and it works OK. It throws some sawdust forward from the blade. You should do OK. Beats sweeping up a barrel of sawdust.
View alittleoff's profile
alittleoff
539 posts in 1242 days
#7 posted 11-09-2015 04:02 PM
I have a 16 gal. Rigid vac. That I use on my table saw with a 2.5 inch hose and it does fine.I even hooked it up to my 13 in. Dewalt planner and it kept up with it. The planner really through the chips out. I thought it would clog the vac. But it didn’t. I don’t use it on the planner any more but a vac. Should work on your saw.
Gerald
View TheFridge's profile
TheFridge
9249 posts in 1451 days
#8 posted 11-09-2015 04:07 PM
A vac is better than nothing at all and well worth it if you already have a vac.
View Redoak49's profile
Redoak49
3196 posts in 1954 days
#9 posted 11-09-2015 04:18 PM
The answers are interesting. IMHO a vacuum with a 1.25” hose will likely not work well. You need about 4000 fpm to move the chips and dust.
I looked up a 6 hp shop vac with 2.5” hose. The spec shows 179 cfm or about 5264 fpm with that hose. Hooking it up to 4” pipe reduces it to just over 2000 fpm and too low.
Of course any vacuum will help but …..
View TinWhiskers's profile
TinWhiskers
179 posts in 918 days
#10 posted 11-09-2015 04:35 PM
I cut a hole in the top of a 55 gal drum and inserted my shop vac. Works good for my planer and sander.
View Brouss's profile
Brouss
10 posts in 908 days
#11 posted 11-09-2015 04:50 PM
I’m with TheFridge on that one.
- TheFridge
View Karamba's profile
Karamba
116 posts in 902 days
#12 posted 11-09-2015 06:55 PM
Some saws are designed to work with shopvacs. For example Bosch 4100 has 2” port. Delta 36-725 has 2-1/2” dust port and shrouded blade with very air little volume to move. Shopvacs work really well with them.
If you go to an enclosed cabinet saw with a lot of ventilation openings you need a high volume dust collection, which shopvac is not.
View bearkatwood's profile (online now)
bearkatwood
1543 posts in 977 days
#13 posted 11-09-2015 07:49 PM
This should work just fine as long as you can adapt the fittings to work. Just remember to always use it when you are cutting, if you don’t sawdust will build up in the bottom and when you go to use it again it won’t be able to pull through the clog of dust. (ask me how I know) ;)
-- Brian Noel
DTrak
#14 posted 11-09-2015 08:27 PM
Thank you all so much for the feedback. After reading through these and digging more online, I decided that my little shop vac was probably not up to the task. I ordered this instead:
http://www.amazon.com/gp/product/B00AU0FZPA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
It is pretty cheap for a dust extractor and probably something I needed anyway.
Dan
View HarveyM's profile
HarveyM
106 posts in 1988 days
#15 posted 11-09-2015 10:28 PM
Hi Dan:
The Sawstop (PCS) has a 1.25” vacuum port on the blade guard, so you can still use your shop vac for that. In fact that’s how I use mine- a 1hp dust collector on the 4” cabinet port in with a cheapy shop vac attached to the blade guard.
-- Just a Duffer
