Refinishing 1996 stained built-in - scuff sanding to 220 ok?
Forum topic by noone posted 11-09-2015 03:01 AM 666 views 0 times favorited 3 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2470 days
11-09-2015 03:01 AM
I’m refinishing a 1996 built in that is faded. It looks like this built in was stained and then sprayed with a poly, varnish or lacquer. Not sure which. I will be spraying 2 coats of SW Kem Aqua Plus Surfacer primer and then two coats of SW Kem Aqua Plus white. I have been prepping the surfaces by scuff sanding with 220 to ready for primer. Am I good with this or should I be using 150 then 220 after primer?
3 replies so far
View DrTebi's profile
DrTebi
267 posts in 3464 days
#1 posted 02-02-2016 09:57 AM
Maybe a picture would help. I am wondering whether scuff sanding with 220 got all the previous stain and poly off at all? When I refinished a stained and finished oak door, it took forever to get it back to the bare wood. I had to go all the way down to 80 grid for some areas (see this post).
noone
#2 posted 02-02-2016 12:21 PM
I finished this project several months ago.
The regimen I prescribed above worked perfectly. Remember, this was a paint grade project.
DrTebi
#3 posted 02-02-2016 06:42 PM
I didn’t realize the post was that old… I just looked for unanswered post and tried to help.
Of course, if it is a paint grade project, then 220 will suffice!
