Another weekend, more questions (freud adjustable rail bit)
Forum topic by Jackietreehorn posted 11-08-2015 01:43 AM 651 views 0 times favorited 1 reply Add to Favorites Watch
View Jackietreehorn's profile
Jackietreehorn
150 posts in 1900 days
11-08-2015 01:43 AM
Topic tags/keywords: freud adjustable rail
Ok, two quick questions, I have the freud adjustable rail and stile bit, I ran rail bit on a test piece and then measured the tenon @ .225
The plywood panel I have is a mdf core maple veneer, it’s pretty consistent and measures .236-.240 with majority of areas measuring .236. So the question is what number do I want to shoot for, .245? One test run with a shim put it at .243, I know I need some slack for glue correct?
As pintodeluxe was saying in the post from last week, I can glue the panel in so need to make sure there’s room to let glue go somewhere, just not sure what kind of room we’re talking about.
Thanks!!
-- www.nobleprojects.blogspot.com
1 reply so far
View jdmaher's profile
jdmaher
426 posts in 2542 days
#1 posted 11-08-2015 03:12 AM
I’ve used the same bit sets with both plywood and solid wood panels. I don’t glue panels.
I’d use one shim and leave it at that.
-- Jim Maher, Illinois
