Bench hook - Grain direction
Forum topic by Cornelius posted 11-07-2015 01:45 AM 999 views 0 times favorited 5 replies Add to Favorites Watch
View Cornelius's profile
Cornelius
33 posts in 1099 days
11-07-2015 01:45 AM
Topic tags/keywords: bench hook grain direction jig
Hi,
I apologize for coming with such a “rookie” question, but I want to build a set of bench hooks and I don’t figure out why everbody sets the boards with the grain running perpendicular to the one of the fence.
Is it so if the wood moves each grain direction cancels the one of the other? I always thought it was better to keep the same direction in a joint to allow wood movement.
As I want to make a set of 2 hooks I was planning to have the boards running in the same direction as the fence and the stop and crosscut the panel appart…
Thank you for your help
-- Black and White Pictures Portfolio: http://www.axelvonb.com
5 replies so far
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2848 days
#1 posted 11-07-2015 02:58 AM
No expert. I think the grain does run in the same direction on all three pieces
-- Ken
View Tugboater78's profile
Tugboater78
2743 posts in 2190 days
#2 posted 11-07-2015 03:29 AM
If made of solid wood you need them in opposite directions to hinder cupping i believe. But here is a video for some quick and dirty ones.
https://youtu.be/Dx7rZATT9ao
Edit: wow fat fingers tonight..
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
Cornelius
#3 posted 12-27-2015 10:45 PM
Thank you both for your answers. I see it was a trickier question than what I thought…
You have opposite answers and known sources as well:
A known company does it with opposing the grains:
http://www.badaxetoolworks.com/bad-axe-bench-hook-sets.php
And a known editor insists in keeping the grain direction on all the parts:
http://www.popularwoodworking.com/wp-content/uploads/2010/10/Bench-Hook.pdf
For what I have in mind I would prefer to keep the three in line.
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#4 posted 12-27-2015 11:12 PM
Because that is the easiest way. Bench hooks are kind of disposable and are so easy to make that if one fails, it is no big deal to just make another.
-- Bondo Gaposis
Cornelius
#5 posted 12-28-2015 12:24 AM
That makes sense, thank you!
