Water on Oil
Forum topic by CharlesA posted 11-06-2015 07:12 PM 880 views 0 times favorited 9 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3302 posts in 1668 days
11-06-2015 07:12 PM
I keep hearing not to put a water-based finish on any kind of oil.
Here’s some grain-filling advice from Charles Neil’s latest newsletter:
I will rub a good oil, like Arm-R-Seal, into the pores after the color is applied. This mechanical push along with the thinner oil forces the oil into the pore. Rarely does one coat do it. After the oil is well I can brush (foam) a water base finish or rub it on to further fill the pores. I like the water base as it is heavier and fills quicker. It also doesn’t shrink back like a solvent base finish.
Before I knew better, I put water-based on top of oil, and haven’t seen a problem yet. Is conventional wisdom no longer true?
9 replies so far
4823 posts in 2364 days
#1 posted 11-06-2015 08:04 PM
I guess I didn’t know that was “convential wisdom”. I’ve used a waterborne finish on top of BLO several times without a problem. But for me it seemed the trick was to give the BLO plenty of time to cure. I usually wait 5-7 days (depending on temp) in this instance, whereas with solvent based finishes I usually only wait a day or 2.
View Bill White's profile
Bill White
4819 posts in 3831 days
#2 posted 11-06-2015 09:30 PM
Cure time and dewaxed shellac. No prob, no matter, no issue.
Bill
-- bill@magraphics.us
CharlesA
#3 posted 11-06-2015 10:46 PM
Bill
- Bill White
My point was doing it without shellac.
View Rick_M's profile
Rick_M
10813 posts in 2251 days
#4 posted 11-07-2015 12:28 AM
Bill
- Bill White
Good point Bill. No fuss no muss.
-- http://thewoodknack.blogspot.com/
17203 posts in 1727 days
#5 posted 11-07-2015 12:45 AM
I use oil based stain and water based polycrylic all the time. As long as the stain is thoroughly dry there’s no problem.
View mahdee's profile
mahdee
3830 posts in 1638 days
#6 posted 11-07-2015 03:41 AM
I think there is a saying, water on water, is AOK, water under oil is AOK, water on oil, you got a problem. Now, all you have to do is define “oil”.
-- earthartandfoods.com
View Shadowrider's profile
Shadowrider
183 posts in 1080 days
#7 posted 11-07-2015 05:40 AM
I did water on top of oil on my kitchen cabinets with no issues. You just have to let it fully cure. I mean 100% fully cure, not just ”that ought to be close enough”.
View AlaskaGuy's profile
AlaskaGuy
3771 posts in 2180 days
#8 posted 11-07-2015 10:47 AM
These cabinets are an oil base stain with waterborne clear on top. The was applied a couple week before the top coat.
a better picture here:
http://www.forums.woodnet.net/ubbthreads/showflat.php?Cat=&Board=UBB8&Number=7136808&Forum=,All_Forums,&Words=&Searchpage=0&Limit=25&Main=7132563&Search=true&where=&Name=25326&daterange=&newerval=&newertype=&olderval=&oldertype=&bodyprev=#Post7136808
View CharlesNeil's profile
CharlesNeil
2172 posts in 3741 days
#9 posted 11-07-2015 02:25 PM
yep, the oil has to be totally dry
