vacume/exhaust fon
Forum topic by mags posted 12-19-2009 03:17 AM 981 views 0 times favorited 5 replies Add to Favorites Watch
View mags's profile
mags
59 posts in 3087 days
12-19-2009 03:17 AM
Topic tags/keywords: question
Hi guys and girls. i have a resturant exhaust fan that i would like to turn into a vacume. I don`t know how this, or if this will work. any one have any thoughts on this? thanks Nick
-- Nick,Pa.
5 replies so far
View Abe Low's profile
Abe Low
111 posts in 3816 days
#1 posted 12-25-2009 07:21 AM
It is a complex problem. Mostly it depends on the design of the exhaust fan. Do a google search for Bill Pentz. The site has more info than I can relay. From what I know of the issue, I’d recommend you consider using it as an exhaust fan in your shop to keep a fresh supply of outside air and getting rid of the fine dust that keeps floating until it winds up in a pair of lungs.
-- Abe Low, Fine furniture, Sacramento, CA
View MarkwithaK's profile
MarkwithaK
370 posts in 3148 days
#2 posted 12-26-2009 08:15 AM
I work with commercial restaurant equipment including exhaust fans and have never heard of one being used in this exact manner….I suppose on some level it would be possible but would require a lot of work and, more than likely quite a bit of custom fabrication.
-- If at first you don't succeed then maybe skydiving isn't for you.
View mags's profile
mags
#3 posted 12-26-2009 04:53 PM
Thanks Abe and Mark for your input. Iguess i might just contiue to use it as a exhaust fan thanks Mags
-- Nick,Pa.
View Taigert's profile
Taigert
593 posts in 3810 days
#4 posted 12-29-2009 09:14 AM
the two common style fans used are one with a spun aluminum dome such as made by Jenn-Air or a squirril cage fan such as that made by Delphi. Any debris coming in contact with either of these fans will be the end of your fan.
DC fans are typically about 14 Ga. to 10 Ga. welded blowers vs. 24 to 26 Ga. punched out fans .
Big difference, they’ll move lots of air but thats about all
-- Taigert - Milan, IN
View bill1352's profile
bill1352
130 posts in 3091 days
#5 posted 12-29-2009 03:29 PM
I agree that it would not work for a vacuum, not enough static pressure but it would make a serious air cleaner. I used a fan from a window air conditioner mounted in a 20” X 20” box, put 2 poly filters in front of the fan, used a extention cord for power. The wood was scrap 1/2” ply so the total cost was $12. I was in the commercial HVAC cleaning business so the filters were free, about 30 filters left before the cost goes up.
-- Keep Your Stick On The Ice
