Framing Lexan Interior Strom Windows
Forum topic by ramone posted 11-06-2015 02:54 AM 523 views 0 times favorited 2 replies Add to Favorites Watch
View ramone's profile
ramone
18 posts in 1383 days
11-06-2015 02:54 AM
Hello i’m in the process of framing a house-full of Lexan Interior Strom Windows.
The lexan is 4’x8’ and 7/64” thick. I have some 1×2 furring strips that i’m going to cut a groove into with my circular saw to receive the Lexan; kind of a mortise-tenon with the lexan being the tenon. Once the frame is ready to receive the lexan i plan to add some adhesive … glue? caulk? ... something to stabilize the lexan within the grooved wood frame.
Essentially i’m wrapping the lexan in a wood frame, which i’ll further wrap with weather-stripping, and add pull-tabs to facilitate moving the storm window in and out when needed.
So i’m wondering how to tell at a glance what the kerf-width is of a circ-saw blade, so i can make sure i have what i need to cut the groove.
Lastly … any suggestions for helping to make this a successful project : )
Thanks …
2 replies so far
View Woodknack's profile
Woodknack
11145 posts in 2289 days
#1 posted 11-06-2015 06:09 AM
You can look up the blade specs on the manufacturer’s website, that will tell you the size.
But a set of brass calipers are super useful to have around the shop.
-- http://thewoodknack.blogspot.com/
View dhazelton's profile
dhazelton
2689 posts in 2206 days
#2 posted 11-06-2015 12:52 PM
You can use 100% Silicone sealant on lexan. I don’t know why you would need to glue the panels into the frames, though, unless it’s just to be POSITIVE there will be no air infiltration.
