Need help working with veneer, staining, and gloss
Forum topic by knight2255 posted 01-24-2010 10:52 AM 982 views 0 times favorited 1 reply Add to Favorites Watch
View knight2255's profile
knight2255
1 post in 3075 days
01-24-2010 10:52 AM
I’m an amateur telescope maker, I’m trying to get the upper part of this
telescope
to look like this
drum
The upper and lower octagon and dowels will be the maple color and the black shielding will be the cherry colored stuff. I am undecided for the mirror and rocker box at the bottom, I was thinking a 1” maple band around the top and bottom of the boxes and the cherry look inbetween.
I’m using inexpensive ordinary maple veneer on top of an aspen plywood. I think I can only use an oil based stain with veneer. Do local paint shops usually carry a cherry and maple colored stains like that? What steps do I need to take gluing, sanding, and topcoating to get that look? Thanks
1 reply so far
View Ger21's profile
Ger21
1074 posts in 3125 days
#1 posted 12-19-2009 07:58 AM
I’d use water soluble aniline dye for the cherry color. Maple is very difficult to stain evenly, but you can dye it rather easily, and dyes come in any color you’d want.
Use a clear laquer finish, and rub out the final coat for that high gloss. You’ll probably need at least 6 coats. If you’ve never done it, you should make some samples to get some practice.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
