Milling
Forum topic by ScottM posted 11-05-2015 05:13 PM 714 views 0 times favorited 11 replies Add to Favorites Watch
View ScottM's profile
ScottM
574 posts in 2019 days
11-05-2015 05:13 PM
I’m now working on my first project using “rough” lumber. I found a local yard that had prices that I just could not pass up versus the prices at my local Lowes. Outrageous! So I managed to get to the yard and come home with 10 8 foot full 4/4 boards of red oak for my project.
Now on to the real questions. I rough cut a couple of the pieces into smaller lengths and did the usual, joint plane, over size cut, and sticker it overnight. The following day finished up the milling and cutting to final size. All of that seems to have gone well. Now I on to a portion of my project where I don’t need to use any of the remaining rough pieces. So should I go ahead and rough mill it or just leave it as is until I need it? Any advice would help here. Thanks in advance.
11 replies so far
View rwe2156's profile
rwe2156
2749 posts in 1353 days
#1 posted 11-05-2015 05:19 PM
Do whatever you want.
To me its easier to mill it all while you’re doing it.
I also mill an extra piece to final dims if (when) I mess up.
View jdh122's profile
jdh122
969 posts in 2690 days
#2 posted 11-05-2015 05:19 PM
Leave it as is until you need it. Except that you need to make sure that you have enough scraps of the same thickness as your pieces to do test cuts before running the real pieces through the tablesaw and router table.
-- Jeremy, in the Acadian forests
View Mike's profile
Mike
406 posts in 2559 days
#3 posted 11-05-2015 05:22 PM
Leave it un-milled. Wood will continue to move even if it is milled. By leaving it alone, when you do need it, you won’t be working with a board that needs correction from warping, bowing, twisting, or some other -ing thing.
-- look Ma! I still got all eleven of my fingers! - http://www.lepelstatcrafts.etsy.com - https://www.youtube.com/channel/UCppWfrYGXCr5lm9uW-Fpqqw
View joey502's profile
joey502
519 posts in 1390 days
#4 posted 11-05-2015 05:49 PM
Keep them rough. Mill the boards from rough as needed on future projects.
View Monte Pittman's profile
Monte Pittman
27688 posts in 2210 days
#5 posted 11-05-2015 06:04 PM
Leave it rough. It also leaves your options open for future projects.
-- Mother Nature created it, I just assemble it.
View SirIrb's profile
SirIrb
1239 posts in 1103 days
#6 posted 11-05-2015 06:12 PM
never assume what you will need. Mill later.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2685 days
#7 posted 11-05-2015 06:20 PM
My 4/4 I usually leave rough. 5/4 and 6/4 it’s no problem to mill it to rough dimensions ahead of time.
It’s hard to anticipate what thickness you may need for the next project, so leaving it rough gives me more options.
View bonesbr549's profile
bonesbr549
1469 posts in 2939 days
#8 posted 11-05-2015 06:23 PM
I’d leave it rough. Mainly due to when you buy more stock for a project later, you can mill it all at the same time, and get it all to uniform thickness. (color stays a bit better too as oxidation will be more constant, but keep in mind diff lots diff colors. I work mostly in cherry and thats a huge issue. Cheers.
ScottM
#9 posted 11-05-2015 06:25 PM
Thanks for all the help. The majority of what I have I will be using on this project and I guess it was really, mill it now while I was at it or wait. I know I’ll have an overage so I’l leave that rough. Thanks again for the suggestions.
View bearkatwood's profile
bearkatwood
1449 posts in 884 days
#10 posted 11-05-2015 06:32 PM
I would leave it alone. If you are going to do anything, just give it a light pass so you can see what you have to work with when you go back in the pile to see what you have.
-- Brian Noel
View JAAune's profile
JAAune
1772 posts in 2189 days
#11 posted 11-07-2015 06:26 AM
Don’t waste time doing more work than necessary just because it might save a little time in the future. Cut what you need and leave the rest rough.
Brian did make a good point above about skimming the surface just enough to make the surface visible. My lumber is purchased this way instead of 100% rough. It’s called “hit-and-miss” and I like the fact that I can see the grain patterns right off the truck.
