Threaded Inserts
Forum topic by Chris Radvansky posted 11-05-2015 04:14 AM 899 views 0 times favorited 13 replies Add to Favorites Watch
View Chris Radvansky's profile
Chris Radvansky
15 posts in 962 days
11-05-2015 04:14 AM
so I was building this badass ROUTER TABLE!!! and to have the fence pieces slide a bit across the bit, the plans called for a threaded 5/16” insert. The plans said to fit said insert, I should use a 9/16” forstner bit. When I drilled the cylindrical hole, I found that the hole was too big for the insert. Any tips you have when the hole is too big for the insert other than to start from scratch with a new piece of wood? Thanks everyone.
Chris
-- Chris
13 replies so far
View ForestGrl's profile
ForestGrl
450 posts in 1081 days
#1 posted 11-05-2015 04:21 AM
Chris
- Chris Radvansky
Depending on how picky you are about appearances…...you can take a hardwood face-grain dowel and insert it in the over-sized hole (may have to drill the hole out a little if you can’t find the exact fit), glue that in, let it dry overnight, then redrill the right sized hole. Moral of the story: Always do a test drill on scrap when doing something new [I’m sure you can figure out how I know this story and its moral. ;-) and how to fix it ]
PS: I’m not sure why you would need to use a Forstner. The few threaded inserts I’ve done, I’ve used a brad-point bit.
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
View jerryminer's profile
jerryminer
923 posts in 1436 days
#2 posted 11-05-2015 05:20 AM
Epoxy
View HokieKen's profile
HokieKen
4971 posts in 1133 days
#3 posted 11-05-2015 07:59 PM
I’m not picturing exactly what you’ve got but, if there’s room, you could just drill a hole, the correct size below the 9/16 hole and put the insert in there and use a longer bolt/screw.
If that’s not a possibility, I’m with ForestGrl, drill the hole out and epoxy in a 5/8 HW dowel. Then just drill the dowel out to the correct size.
-- Kenny, SW VA, Go Hokies!!!
View b2rtch's profile
b2rtch
4861 posts in 3043 days
#4 posted 11-05-2015 08:28 PM
Dowell and drill again
-- Bert
View ChefHDAN's profile
ChefHDAN
1062 posts in 2844 days
#5 posted 11-05-2015 08:37 PM
FWIW
9>5 therefore 9/16” >5/16” and a 5/16” item will fit through a 9/16” opening but not be retained by it, this is commonly known as the DOH! rule and sometimes the WTF rule
Welcome to the wonderful world of woodworking where screwing up is always educational and mostly funny so long as you keep all your appendages attached.
View Kazooman's profile
Kazooman
1005 posts in 1947 days
#6 posted 11-05-2015 08:52 PM
FWIW
- ChefHDAN
FWIW – 2
5/16 is the size of the bolt that threads into the insert. The external size of said insert will be much larger. The 5/16 brass insert McFeeley’s sells call for a 1/2” hole. The 9/16 that the OP mentioned would be very reasonable for another brand.
You are correct about one thing. Screwing up IS always educational.
View nkawtg's profile
nkawtg
276 posts in 1246 days
#7 posted 11-05-2015 09:04 PM
Yup, something like a Dutchman / oversize dowel will do nicely, then re-drill.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#8 posted 11-05-2015 09:09 PM
Use a threaded insert that fits a 9/16” hole.
View rwe2156's profile
rwe2156
2920 posts in 1475 days
#9 posted 11-05-2015 09:31 PM
1. Epoxy
2. Dowel and redrill
3. Get diff inserts.
In order of preference.
View SirIrb's profile
SirIrb
1239 posts in 1225 days
#10 posted 11-05-2015 10:10 PM
I think there was a type-o and toy were supposed to use a 5/8 insert. Would make more sense.
Dowel. And always reply to people when they question it with “you don’t preDowel your inserts? If you calculate the elasticity of the wood to the holding power of the glue, the vector and feed rate of the work piece and divide that by the routers rpms, you would get it.” Act insulted till they beg forgiveness and recognize (imagine) your genius.
ForestGrl
#11 posted 11-06-2015 05:35 AM
- ChefHDAN
My own personal fave: the first time I used my new Freud dado set (what, 10 years ago?), I was so obsessed with setting the blades perfectly, I had it in the saw backwards. Ahhh, the smell of burning plywood! ;-)
View Redoak49's profile
Redoak49
3239 posts in 1983 days
#12 posted 11-06-2015 12:37 PM
There is so much difference in brands of threaded inserts. I always do a trial hole just to make certain.
I make lots of mistakes but try not to make the same one more than a couple of times.
View Bluepine38's profile
Bluepine38
3379 posts in 3080 days
#13 posted 11-06-2015 08:17 PM
Redoak49, I was told the first time it was a mistake, the second time it was a choice. Do not ask why I
was told this.
