Amana 10" 60T AGE Series 5/8" arbor bore on Sale - Any good?
Forum topic by dalec posted 12-17-2009 10:15 PM 1036 views 0 times favorited 2 replies Add to Favorites Watch
View dalec's profile
dalec
613 posts in 3761 days
12-17-2009 10:15 PM
Topic tags/keywords: question
Just ran across a special listed on Highland woodworking.com for an Amana I copied the following:
“This 10” table saw crosscut blade has 60 Alternate Top Bevel (ATB) teeth with a 12° positive hook for smooth crosscuts in solid wood. 5/8” bore, .126” kerf. Amana #MD10-600”.
The blade is on sale for $29.99. I have a Forrest Woodworker II 40T on my saw that I have been using for all my cutting. Have been cutting some plywood recently and get a bit of splintering. Would the Amana with its 60T cut provide a better cut on plywood or cross cutting hardwood?
Dalec
2 replies so far
View NathanAllen's profile
NathanAllen
376 posts in 3017 days
#1 posted 12-17-2009 10:54 PM
Hardwood certainly better. For ply it should be better than the WWII, but a blade with more agressive bevel and less agressive hook will be smoother for crosscutting ply. Forrest Duraline or Chopmaster blades and Freud LU80R are tops in my book for cross cutting ply.
dalec
#2 posted 12-18-2009 03:21 AM
Thanks NathanAllen.
I am pretty happy with the Forrest WWII blade, but have this idea that I might get a cleaner cut with a dedicated high tooth count saw blade for cross cut and plywood. Then again, investing in a higher end cross cut/plywood blade is no where near the top of my list of things I want to spend my limited budget on at this time. The $29.99 would be a good deal if the Amana A.G.E. series blade were able to give me cleaner cuts cross cutting hardwood and plywood.
I may just sit this one out.
Again, thanks for the response.
Dalec
