Problem with my Ridgid scroll saw.
« back to Scrollsawing forum
Forum topic by Sam777 posted 11-04-2015 04:40 AM 1141 views 0 times favorited 8 replies Add to Favorites Watch
View Sam777's profile
Sam777
10 posts in 933 days
11-04-2015 04:40 AM
Hi.
This is my first post (after profile intoduction).
I bought a used ridgid scroll saw. I cut a few test pieces and it worked fine. I figured out how to adjust the tension.
I changed blades (what a pain in the neck) just to see which blade works best. Then the tension knob kept coming loose. I think i am missing some kind of a locking gaget to keep the tension knob from coming loose. I tried to open the saw to see what is wrong but that is another issue. I’m trying to attach a photo of the tension knob but havent figured out how to attach yet.
The model is SS1650.
thanks for the help
8 replies so far
View ForestGrl's profile
ForestGrl
450 posts in 1083 days
#1 posted 11-05-2015 04:00 AM
Used saw…..do you have the manual? I looked it up, hoping it might be similar to the Delta I once had, but it isn’t. Here's a link to the manual. Hopefully, someone here at LJ owns one. (The Delta has a quick-release, in addition to tensioning knob, etc. (Rigid doesn’t look so user friendly, bummer)
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
View Kaleb the Swede's profile
Kaleb the Swede
1833 posts in 1966 days
#2 posted 11-05-2015 04:11 AM
Hi Sam. I have a similar saw (central machinery) it looks like it was built in the same factory. I think that you might have the same problem that I had with mine.
The screw for the tension was stripped out. I ordered a ryobi scroll saw replacement tension screw (exact size to mine and yours I believe) from ereplacementparts.com. If you open the screws on the side of the saw and get to the back of it you may see the same thing I did.
Now I have to remind myself not to over tension it.
Hope this helps
-- Just trying to build something beautiful
Sam777
#3 posted 11-05-2015 04:46 AM
ForestGrl,
Thanks for the quick reply. I downloaded a partial manual (3 pages). that is all I found and it is only about an explode view assembly, no trouble shouting….
Kaleb,
Thank you for your reply. The side screws are so over-tighted that I was afraid to crack the casting. I removed them all but the bottom one which is so burried between the upper and the lower casting. I will have to remove the bottom casting 1st to access that last screw. For now, I’m leaving it alone. I did a little practice today and was watching if the tension knob moves. I thing I had it too loose yesterday. I will continue to practice this one but I am hoping to step up to an Excalibur 16. ( I have been reading Sheila’s old blogs on this forum (#313, 314, 315…..) which impressed the heck out of me and decided that the next saw would be the Excalibur 16. I will have to read more recent blogs but “so much to read, so little time”
I am still trying to find my way around the forum.
Thank you both again for the prompt reply :)
Sam
ForestGrl
#4 posted 11-05-2015 05:05 AM
ForestGrl,
[Snip]
- Sam777
So you followed the link I provided, right? That’s 28 pages, good night-time reading, LOL. Wish Delta still made the SS250. It was an affordable saw that, equipped with Flying Dutchman blades, could do some decent work—I made quite a few Christmas ornaments with it during my scroll saw phase. There’s one on eBay now, missing the upper blade clamp, don’t know if the parts are easy to come by.
Sam777
#5 posted 11-14-2015 08:40 PM
Hi again,
Sorry for the disconnect.
I got a little used EX16 for a great price.
Now waiting for better blades FD to arrive so I can really start scrolling.
I will be asking more questions.
Thanks for the help
Sam
MrUnix
6708 posts in 2196 days
#6 posted 11-14-2015 08:48 PM
Oh my… I guess that is one way to fix the tension problem!
ForestGrl
#7 posted 11-15-2015 03:44 AM
Hi again,
Thanks for the help
Sam
- Sam777
You will love the Flying Dutchman blades!
View Planeman40's profile
Planeman40
1176 posts in 2758 days
#8 posted 11-15-2015 04:29 PM
Try this trick to keep the tension knob from moving. Put a lock washer beneath the tension knob. You may have to bend the lock washer open a tad more to get more grip on the knob if there is still a problem. Also, putting a stiff spring beneath the knob works too.
Planeman
