| Forum topic by bues0022 | posted 1251 days ago | 515 views | 0 times favorited | 2 replies | ![]() |
1251 days ago |
I just completed (I thought) a freehand routered sign as a Christmas present yesterday. It is made from three woods: Hickory, Ash, and Paduk. My initial finish was with tung oil as per the directions on the can. I like using the Tung oil because it ends up being almost a flat finish on the flat surfaces, but in the grooves where it builds up really thick it ends up as a gloss finish. I have a problem though, there are a few places on the Ash that the wood looks a bit dry. This hasn’t happened to me before, so I’m trying to fix it. Should I hit it with another coat of the tung oil? Or, do I wipe it with a paste wax? I’ve never used was a a surface coat before, so I’m hesitant to try it over the tung oil without knowing it will be ok. Thoughts? -- Ryan -- Maple Grove, MN |
