Hand mortising tool?
« back to Hand Tools forum
Forum topic by Josh posted 11-02-2015 06:11 PM 660 views 0 times favorited 5 replies Add to Favorites Watch
View Josh's profile
Josh
19 posts in 1475 days
11-02-2015 06:11 PM
Topic tags/keywords: chisel joining arts and crafts question
A couple nights ago I watched a bunch of different random woodworking videos on youtube. One video had a guy using a 4 sided chisel for mortising (just like an electric mortiser/drill bit would have) but this had a roundish top that he struck with either a hammer or mallet.
Did I just dream this or does this unicorn exist?
Also, if it does exist, could I use it after drilling a hole with a forstener bit to square out the sides? (Why yes, I am looking for a way to make mortises easier without buying a mortiser.)
5 replies so far
View HokieKen's profile
HokieKen
4594 posts in 1008 days
#1 posted 11-02-2015 06:17 PM
I’ve never seen a 4-sided one. I’ve seen 2 sided “corner” chisels but haven’t ever really heard anything good about them. I guess if you really wanted a 4 sided one you could buy a chisel for drill press type mortising machine and fit a handle to it for striking.
-- Kenny, SW VA, Go Hokies!!!
View bondogaposis's profile
bondogaposis
4524 posts in 2221 days
#2 posted 11-02-2015 06:30 PM
I have a square hole punch. Like this. It is only for using with decorative plugs, they don’t cut very deep. I couldn’t imaging mortising w/ them.
-- Bondo Gaposis
View AZWoody's profile
AZWoody
1192 posts in 1093 days
#3 posted 11-02-2015 07:48 PM
You can get this and slide it over a mortise machine chisel. Was this what he had?
http://www.rockler.com/mortise-chisel-handle-chisels-not-included
View Josh's profile
Josh
#4 posted 11-02-2015 08:18 PM
- AZWoody
Very close. It was metal, but this will do in its stead perfectly. Thanks!
View pintodeluxe's profile
pintodeluxe
5541 posts in 2683 days
#5 posted 11-02-2015 08:29 PM
Lee valley sells them, but as Bondo mentioned they are only good for decorative pegs and shallow holes. The handheld versions are a little more stout than the hollow chisels used or mortising joinery. They are called square hole punches, and some versions allow you to run a drill bit down a hole in the top. The problem is, there is nothing to guide your hands to stay vertical.
The sad thing is buying a benchtop mortiser might actually cost less than a full set of the handheld variety.
