computer program to manipulate drawings
Forum topic by Kiwib0y posted 11-02-2015 05:11 AM 953 views 2 times favorited 15 replies Add to Favorites Watch
View Kiwib0y's profile
Kiwib0y
89 posts in 931 days
11-02-2015 05:11 AM
Topic tags/keywords: computer program
With so many talented woodworkers out there is there anyone who can suggest a computer program that I can use to stretch, enlarge or generally manipulate designs or figures, I find so many good designs but will not fit the size of projects I propose to use it for. Weather it is for Marquetry or scroll sawing down here in New Zealand it is hard to find some one who can appreciate what I am doing.
-- "It is only a silly question if it is not asked" Don,New Zealand
15 replies so far
View bandit571's profile
bandit571
19236 posts in 2592 days
#1 posted 11-02-2015 05:14 AM
Yep….it is called “Sketch-up” Might have to download a bit of it….
As for myself, I use a Single Brain Cell Sketch-up.
Most on here will use the “normal” Sketch Up Programs….
I’m sure someone will soon show up with a site for you to download from.
Kiwib0y
#2 posted 11-02-2015 06:31 AM
Here 1 New Zealander been bought up to speed with technology, I thought Sketch up was 3D only. back to the computer.. Thanks bandit571
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#3 posted 11-02-2015 06:36 AM
Sounds like you are looking for something to manipulate patterns for cutting out on the scroll saw? If so, between Gimp and Inkscape (both free), you can do most anything needed.
Kiwib0y
#4 posted 11-02-2015 07:13 AM
Thanks for your guidance Brad.
View helluvawreck's profile
helluvawreck
30177 posts in 2775 days
#5 posted 11-02-2015 02:59 PM
I really do like Corel Draw but it may be more than what you are looking for.
helluvawreck aka Charles
View Notw's profile
Notw
614 posts in 1662 days
#6 posted 11-02-2015 07:35 PM
If they are basic 2D drawings Draftsight isn’t bad and it’s free
View Redoak49's profile
Redoak49
3078 posts in 1897 days
#7 posted 11-02-2015 09:24 PM
I do quite a bit of scroll saw work with puzzles and such. I will scan a pattern to jpeg and then insert it into PowerPoint. Once there I can change the size or make it longer or shorter. It is one way to do it.
As a footnote…...I got really upset using the AWFUL software with my HP scanner. I now use a program called Vuescan for all my scanning and works with a huge number of different scanners.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1484 days
#8 posted 11-03-2015 03:22 AM
Big print.you load the drawing on to the graph paper format,tell it how big the squares are.and it sizes it.
Kiwib0y
#9 posted 11-03-2015 06:09 AM
Thanks for the reply guy’s, certainly gives lots of wanted options.
View shipwright's profile
shipwright
7896 posts in 2707 days
#10 posted 11-03-2015 02:50 PM
I use inkscape. PM sent.
View Ghidrah's profile
Ghidrah
667 posts in 1131 days
#11 posted 11-03-2015 04:43 PM
If all I’m doing is enlarging or shrinking an image my printer does that for me to the extent of the 8X11” paper it uses. If I need bigger than my HP Officejet can provide, I put a copy on my usb drive and go to Staples.
-- I meant to do that!
View XquietflyX's profile
XquietflyX
339 posts in 869 days
#12 posted 11-03-2015 04:57 PM
sketchup is great for 3d and can even give you cut lists with the plug in
-- You can tell a lot about your wife by her hands, for example if they are around your throat she's prolly pissed off at you...
shipwright
#13 posted 11-03-2015 09:13 PM
I think he is looking for a program to draw and re-draw designs for cutting in marquetry (or general scrollsaw). Sketchup isn’t any good for that.
The nice thing about vector graphic programs like Inkscape is that you can do all the manipulations you like with the lines at any size and then re-size to any other size and retain (or change) the line thickness. This is really important for accurate cutting.
There are several of these but Inkscape is free and does all I need it to do.
View MrRon's profile
MrRon
4638 posts in 3152 days
#14 posted 11-04-2015 06:21 PM
If you only want to enlarge or reduce an image, you can do it with a copy machine.
shipwright
#15 posted 11-05-2015 04:11 AM
......... but the line thickness will change with the size.
