4 shoulders versus ... ?
« back to Joinery forum
Forum topic by bryonellington posted 11-01-2015 07:24 PM 688 views 0 times favorited 4 replies Add to Favorites Watch
View bryonellington's profile
bryonellington
3 posts in 931 days
11-01-2015 07:24 PM
Topic tags/keywords: tenons tage frid 4 shoulders
In the Dec FWW, Garrett Hack paraphrases Tage Frid saying don’t use 4 shoulders around a tenon. Anyone a follower of that Tage Frid that could help explain how many shoulders he advocates and under what circumstances?
View ElChe's profile
ElChe
630 posts in 1329 days
#1 posted 11-01-2015 07:58 PM
Frid advocated not using 4 shoulders unless necessary to hide the joint because it made it difficult to fit the joint and also the reduced glue surface. He preferred some version of a haunched tenon. I’m no expert but it seems that with newer glues the glue surface in a four shoulder tenon should be plenty strong provided the tenon is appropriately constructed? Not sure if link will work but it is from Frid’s awesome book.
https://books.google.com/books?id=YXlDT6lZBCIC&pg=PA160&lpg=PA160&dq=tage+frid+tenon+shoulders&source=bl&ots=lxxa6UtGKi&sig=_aBiEDaeqiuR0du-FyLyP_LkOMY&hl=en&sa=X&ved=0CDwQ6AEwCWoVChMIn6CEk__vyAIVQtgeCh3rRg1M#v=onepage&q=tage%20frid%20tenon%20shoulders&f=false
bryonellington
3 posts in 931 days
#2 posted 11-02-2015 03:38 AM
Thanks for the book link; appears to work (just not properly on my iPad, of course).
Makes sense. Strange how much effort I put into cuts and surface prep for areas only people like us would appreciate/notice.
ElChe
#3 posted 11-02-2015 04:21 AM
Tage Frid devotes a nice section to the full blind dovetail. Cool joint but only you would know it is there! :)
bryonellington
3 posts in 931 days
#4 posted 11-08-2015 02:24 PM
I’ve never seen a full blind dovetail. :-) Thank you!!
