How square is square enough?
Forum topic by TopamaxSurvivor posted 12-16-2009 08:07 AM 4879 views 0 times favorited 104 replies Add to Favorites Watch
TopamaxSurvivor
18423 posts in 3914 days
12-16-2009 08:07 AM
Topic tags/keywords: square squares tolerance
Occasionally, there has been discussion of squares being truly square on LJ. Lately, I have checked a few. My own framing square has been checked several times and my combination squares against it. They all show square. Tonight, for curiosity, I checked the framing square using 3,4, 5 right triangle measurements. It measures dead on. I double checked it with my Wixey, again, dead on. I have randomly checked framing squares in the big box with a 3,4, 5 measurement. I have yet to find one that is off. I’m getting curious as to why everyone else has out of square squares?? What are you doing that these methods aren’t good enough?
104 replies so far
View BlankMan's profile
BlankMan
1490 posts in 3591 days
#1 posted 12-16-2009 08:12 AM
How are you doing the 3, 4, 5 measurement? Relying on the 3, 4 stamped on the square? :)
But you gave me a good idea, I’ll check mine with my Wixey and see, I’ve always used my Starrett square before. Lord help if that’s off! ;)
-- -Curt, Milwaukee, WI
TopamaxSurvivor
#2 posted 12-16-2009 08:15 AM
Actually, I’m multiplying by 4; therefore, using 12 & 16 on the scales and measuring the diagonal with my tape.
BlankMan
#3 posted 12-16-2009 08:46 AM
I just measured a really old 24” square I have, it’s 0.2 degree off inside and out.
A newer 12” is 0.1 degree off on the outside, ok on the inside.
A newer 24” is 0.1 degree off on the inside and dead on the outside.
But even at 12×16 0.1 degree is only 0.020” off at 12”, is your tape that accurate?
These things are stamped out on a punch press, are punch presses all that accurate? Maybe they’re ok for framing a house?
Maybe they don’t really care about square, they just put the markings in the right place so the 3, 4, 5 rule works. LOL
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3345 days
#4 posted 12-16-2009 08:47 AM
I usually tape a piece of paper to my saw top, align the short end of the square to the table edge and make a line on the paper. Flip the square 180 degrees and check the alignment with the mark I just made. Can not fail.
TopamaxSurvivor
#5 posted 12-16-2009 08:57 AM
it’s just a standard ol’ Stanley. Considering wood movement, what would one need to square that a tolerance of +/- o.1 degree would matter?
BlankMan
#6 posted 12-16-2009 09:09 AM
Let’s say your making a cabinet, you cut the boards to 18” width, you then crosscut them and you’re off by 0.1 degree, that’s a 1/32” at 18”. You measure the length at each edge and it’s the same and what you want, but it’s a trapezoid not a rectangle. And if all four boards are this way you put it together aligning the edges and it’s not square. Hmmm. What happened?
My machines are dialed in to 0.001-0.002”, time consuming to do but when I make something that is a square or rectangular I don’t have to put a clamp across two corners to pull it square and hold it there while the glue is drying.
TopamaxSurvivor
#7 posted 12-16-2009 09:35 AM
I suppose a hobbist would do that, but I doubt if the production shops would care. :-)
View mtkate's profile
mtkate
2049 posts in 3563 days
#8 posted 12-16-2009 11:24 AM
I still remember my teacher going on and on about square squares. He said the root cause was buying cheap ones. Of course, repeatedly dropping a good one doesn’t help either….
View stefang's profile
stefang
16214 posts in 3572 days
#9 posted 12-16-2009 02:07 PM
Well Bob, I tend to agree with you. We don’t really need to obsess over absolutes, but some folks have to in order to be satisfied. I say more power to them. Myself, I’m satisfied with staying on the wrong side of perfect if for no other reason than to save my sanity. We guess we need both types of people to maintain balance in the world. Yin and Yang?
View Moron's profile
Moron
5032 posts in 4132 days
#10 posted 12-16-2009 02:18 PM
easy method to check
put the framing square against a crisp edge of a piece of plywood and draw a pencil line, then flip the square and check if the pencil line is perfectly parallel. Do it with both the 16” edge and the 24” edge.
View rhett's profile
rhett
742 posts in 3905 days
#11 posted 12-16-2009 03:35 PM
I used to work for a trim carpenter, when I would make comments about something being in or out of square his reply was always “square is a theory”.
-- Doubt kills more dreams than failure.
View marcb's profile
marcb
768 posts in 3912 days
#12 posted 12-16-2009 03:57 PM
I don’t remember my trig well enough to tell you how much .1 degree is going to affect you on case work, but every time a production shop handles something twice to clean up an edge they lose money. If they don’t care, then thats bad business.
It’s easy enough to make sure things are correct up front and not have to worry about it.
Wood movement isn’t an excuse for sloppy work. Wood moves in known and predictable ways that should be incorporated into a design.
16281 posts in 4456 days
#13 posted 12-16-2009 04:18 PM
It’s funny how we all seem to fall into one of two camps. One group says “close is close enough” and the other group strives for perfection.
It reminds me of how my dad (a civil engineer) explained to me many years ago the difference between a mathematician and an engineer.
He said, “Let’s suppose a nude woman is standing on the other side of the room 20 feet away, and you are allowed to approach her incrementally by closing half the distance at a time. The first time you move 10 feet closer, then 5 feet closer, then 2.5 feet closer, and so on. Now, from the mathematician’s point of view, you will never reach her, but, from an engineering standpoint, you can get close enough.”
Close enough for what exactly I was never quite sure. :-)
View Walnut_Weasel's profile
Walnut_Weasel
360 posts in 3460 days
#14 posted 12-16-2009 04:52 PM
I test for square in the same method mentioned above of drawing a line, flipping the square 180 and checking it again. You can also test levels this same way. Shim one end to until it is level, then flip it 180 degrees. I have bought several box store squares AND a “value” square from Woodcraft that are, in my opinion, very unsquare. I did not measure the exact amount out, but we are talking more than 1/32” over 6”.
Something else to consider – the amount of acceptable error is also impacted by the scale of the project. If you are out of square 1/32” on a joint for a 6” jewlery box it looks much worse than being out 1/32” on a full size computer desk simply because of how your eyese focus on the two different objects.
-- James - www.walnutweasel.wordpress.com
View PurpLev's profile
PurpLev
8548 posts in 3887 days
#15 posted 12-16-2009 05:24 PM
Charlie – that was priceless!
fact that wood moves has nothing to do with squareness.
the fact that wood moves should be accounted for equal measurements across the entire project (parallel parts or equal length that will move together) but a square joint/corner, needs to be square!
of course we cannot have perfect 0.000” error margin, but we should strive to get as close to it as possible especially with case work. where unsquareness WILL throw the entire project off. then you need to start redoing each and every piece to match the error instead of having everything precut and ready to go.
but as mentioned – beauty is in the eye of the beholder. and so is squareness (look at Picasso). woodwork is a visual art – as long as it looks good , it’s square enough for me ;) (ok , maybe not to me… but for some)
showing 1 through 15 of 104 replies
