Need advice on Jet JES 14MW
Forum topic by abehil posted 10-31-2015 08:07 AM 719 views 0 times favorited 8 replies Add to Favorites Watch
View abehil's profile
abehil
104 posts in 1208 days
10-31-2015 08:07 AM
Topic tags/keywords: bandsaw help advice question
I’d like some advice on a 14” bandsaw on CL. The owner says it needs a new guide. How big of a job is it to change out a guide? I have a 12” and would really like to move up to a 14”. The price is right if it won’t cost too much to make it run.
Also, was this generally a good model?
http://seattle.craigslist.org/see/tls/5293469512.html
8 replies so far
View b2rtch's profile
b2rtch
4847 posts in 2918 days
#1 posted 10-31-2015 10:45 AM
To replace the guides should be really easy.
Which type of guides are on the saw?
Most 14” band saw are basically the same, not much difference.
Could you go to 17” as you are going to out grow this one very fast?
What is the price? I cannot see it.
-- Bert
View weldoman's profile
weldoman
114 posts in 1927 days
#2 posted 10-31-2015 12:31 PM
It says free!
-- missouri, dave
b2rtch
#3 posted 10-31-2015 06:44 PM
Free is always a good price if it works if not this only more trash in your shop.
-- Bert
View TheFridge's profile
TheFridge
8634 posts in 1356 days
#4 posted 10-31-2015 06:55 PM
Quit talking and go get it.
MrUnix
6186 posts in 2069 days
#5 posted 10-31-2015 06:56 PM
A free BS and you are asking if you should go for it??! Where is my 2×4 so I can slap you up side the head. The real question is if it’s still available, as it isn’t going to be out there for very long. OWWM rule #5 springs to mind.
PS: That machine is a clone of the Delta, and parts should be available for it. Worse case would be you decide not to fix it, and slap it back out on CL for $50 or so as a parts machine (and maybe keep the motor for yourself :)
abehil
#6 posted 10-31-2015 06:57 PM
- b2rtch
Yep, I’m keeping that in mind. I searched for parts for this BS and all are discontinued. I hear a lot of them are similar but I don’t have any idea which ones share parts. Some link mentioned Carter guide which I think this link says would cost $179.
http://www.rockler.com/carter-band-saw-bearing-guides
http://www.ereplacementparts.com/jet-jbs14mw-vertical-bandsaw-parts-c-32652_32684_205179.html
MrUnix
#7 posted 10-31-2015 07:31 PM
I searched for parts for this BS and all are discontinued. I hear a lot of them are similar but I don t have any idea which ones share parts.
Trying to find parts that you don’t even know if you need or not is kind of a waste of effort. Get the machine, see what it needs. Most owners are completely unable to accurately describe the machine, even when it’s sitting there in front of them. Could be something as easy as just needing new HSS guide blocks (or existing ones are torn up and just need re-facing), which are just a few bucks and can be sourced just about anywhere. You won’t know until you have your hands on it.
View teejk02's profile
teejk02
479 posts in 995 days
#8 posted 10-31-2015 10:04 PM
“free”? Nothing to lose I guess if the motor works. As noted above I don’t think there is much difference between any of the 14” brands other than color. Roller bearings behind the blades (top and bottom) and a pair of “pinch blocks” (top and bottom) towards the teeth.
