walnut sapwood
Forum topic by olson posted 10-30-2015 02:28 PM 891 views 0 times favorited 8 replies Add to Favorites Watch
View olson's profile
olson
1 post in 1934 days
10-30-2015 02:28 PM
I recently needed (unfortunatly in the way) to take down a walnut tree with ~14” diameter ~8’ long. I was quite surprised how thick the white sap wood layer was ~5” leaving a measly 4” of nice dark stuff. Should I take it to the saw mill or add it to the firewood pile?
8 replies so far
View conifur's profile
conifur
955 posts in 1151 days
#1 posted 10-30-2015 02:37 PM
Sap wood area can be dyed to match the heart wood.
View bearkatwood's profile
bearkatwood
1572 posts in 1011 days
#2 posted 10-30-2015 03:55 PM
If you steam it, it will even out in color a bit, that is why 99% of walnut you can buy has been steamed. Which is also why 99% of the walnut you buy is no good for steam bending. It will still have a lighter color, but it will darken considerably. Just watch for bugs as they love the sapwood and can hide well and appear only after you have put finish on and taken it in the house.
-- Brian Noel
View jmartel's profile
jmartel
7897 posts in 2150 days
#3 posted 10-30-2015 04:42 PM
Need a workbench or wood for shop stuff? I’m not a fan of walnut sapwood, but I could see cutting it up to make functional stuff for pretty cheap.
View soob's profile
soob
266 posts in 1208 days
#4 posted 10-30-2015 04:48 PM
Sell it to a wood turner.
View bold1's profile
bold1
293 posts in 1847 days
#5 posted 10-30-2015 07:42 PM
If you stack it solid, green and put the sap wood between the heartwood it will stain very dark. Cut into a sample board every once in a while to check how deep you want the stain. This is how many mills sell Butternut for Walnut. Once it stains thru you can’t tell them apart.
View AandCstyle's profile
AandCstyle
3052 posts in 2257 days
#6 posted 10-30-2015 10:51 PM
Olson, just remember that if you stain the sapwood to match the heartwood, the heartwood will lighten with exposure to light and the stained wood won’t, at least not to the same degree.
-- Art
View bannerpond1's profile
bannerpond1
397 posts in 1898 days
#7 posted 10-31-2015 03:17 AM
Have the logs flat sawn. Where the sapwood meets the heartwood there may some very interesting grain and color. I am making a box now of homegrown cherry which has the two in one board. I usually quarter saw most of my logs, but this one was so small, like yours, that I just had it flat sawn. In addition to the wild grain, it has the color change. I’m using it for a jewelry box for a friend’s Christmas gift because of the shapes in colors.
-- --Dale Page
View Jim Hoeller's profile
Jim Hoeller
5 posts in 942 days
#8 posted 10-31-2015 01:17 PM
I have been using dye made from the husks of walnuts. Soaking the husks in water will yield a dark brown dye that can be concentrated by allowing the water to evaporate. A few applications of the dye will darken the sapwood.
