I have an original Incra jig, and when I try to make box joints, they come out too tight. I can put them together dry but if I apply glue there is no way that the joints go together wet.
How can I gain a little extra clearance, maybe an extra 1/64 or just a few thousandsths?
I actually broke / crushed a small box trying to clamp the joints closed.
If the joints are the size of the router bit, then try a new bit. Yours may be a little undersize.
If they fit dry, then you can try polyurethane glue. It'll act like a lubricant and the joints should go together easier. Don't use too much, or you'll have a mess to clean up. Epoxy will work too, but is much messier.
When I bought my incra I was told to buy router bits made for the incra. Many of the router bits brands sell sets of router bits for the incra. I bought mine from Woodline. Perhaps as Gerry said, changing the bit will solve your problem. pkennedy
Water-based glues will swell the joints. You might try polyurethane glue instead. it will not cause swelling. Don't use too much though (maybe 1/2 as much as water-based) as it expands while drying and you probably don't want more clean-up work than necessary. It's great to have a really tight fit as long as you can get it together.
With an incra you can just dial the account for the difference in diameter with the micrometer dial. I used to do it all the time with mine. I had one about 12 years ago when I first saw them at a woodworking show. The guy doing the demo actually measured the dimension of a dovetail bit then preceded to make perfect fitting joints all thaks to the micrometer dial on the jig.
I guess my age is showing. I bought MY Incra jig around 1987, the only thing that you can turn is the locking knob.
The earlier posts regarding bit diameter seems to be the solution. I was trying to cut 1/4" joints with an undersized bit. I changed bits to one of proper size and re-cut the joints and they came out fine.
Thanks again fellas.
later,
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
