Cabinet Scraper Sharpening
« back to Hand Tools forum
Forum topic by yourpaldan posted 10-29-2015 03:32 AM 826 views 0 times favorited 10 replies Add to Favorites Watch
View yourpaldan's profile
yourpaldan
2 posts in 969 days
10-29-2015 03:32 AM
Topic tags/keywords: cabinet scraper card smoothing sanding scraping burnishing
Hi guys,
First posting, but been reading the forum for a while now.
Just been getting into using the card/cabinet scrapers…. Wow! I’m offically a convert.
I have 5 of them from Lee Valley and Bahco. Over the past month I’ve watched every video on how to prepare the edge and burr. I’ve methodically tried every technique, and I don’t understand the results I’m getting.
When I go through the full rigamarole (file the edge flat, smooth the edge and sides on sharpening stones to 90 degree angle, burnish the sides, then use burnisher on the edge to make the burr) I get crappy results every time. Just some dust.
BUT… When I simply file the edge flat at 90 degrees, it only takes a few passes with some pressure, then I lighten the pressure… then it works beautifully! I’m consistently getting beautiful ribbons so thin they must be a single cell in thickness. It’s so much faster too! In about 3 minutes i can do the edges of all five scrapers, and then just go to town on my black walnut table top till either it’s perfect, or my thumbs get tired. The finish speaks for itself. No imperfections no matter how close you look!
Why is this happening? Am i missing something here? I’m ready to toss the burnisher in the garbage (metaphorically). My file is the kind with diagonal grooves in only one direction, nothing special. Anyone understand this? Why aren’t people in the videos teaching this technique?
I’m perplexed yet thrilled!
Thanks,
yourpaldan
10 replies so far
View oldnovice's profile
oldnovice
6901 posts in 3395 days
#1 posted 11-08-2015 05:33 AM
I m perplexed yet thrilled!
From what I read in your post it appears that you are doing everything correctly.
Have you looked at the newly burred edges with a magnifying glass to see that you have a good burr?
Could it be, just for the sake of arguement, that you aren’t using it correctly?
View ElChe's profile
ElChe
630 posts in 1364 days
#2 posted 11-08-2015 05:50 AM
To me the William Ng video taught me how to get the burr. A little oil on the burnished and the angle is only maybe 5% from 90. I also Stone the edge using a wet wood block so as not to gouge the stone. And reshaping the burr is so easy with Ng approach. On wider panels I don’t even sand anymore.
View waho6o9's profile
waho6o9
8207 posts in 2604 days
#3 posted 11-08-2015 05:57 AM
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1051 posts in 1093 days
#4 posted 11-08-2015 06:04 AM
I replied to this post as did others on10/28 and now it returns with the same post again as if it is new by OP, 2 post in ten days ??
-- "Tying shoelaces was way harder than learning to Whistle"
View MrUnix's profile
MrUnix
6768 posts in 2226 days
#5 posted 11-08-2015 06:14 AM
There have been a few threads pop up as ‘new’ that were originally posted (and answered) over a week ago… something wacky going on with underlying database around here for sure.
View AandCstyle's profile
AandCstyle
3075 posts in 2285 days
#6 posted 11-08-2015 01:27 PM
Whew! I thought I was having deja vu all over again. :D
-- Art
View SirIrb's profile
SirIrb
1239 posts in 1258 days
#7 posted 11-08-2015 02:59 PM
Ok, I’ll say it. Not just this, which I was positive I replied to, but some effin DW 734 planer threads. Yall see that? 4 or 5 threads on the same day about the same thing.
Me thinks DKV got banhammered but had more than 1 hinge.
If it looks fishy, smells fishy, rub it with red pepper and throw it in a skillet: it’s fish.
Ok, I’m done.
View Jim Finn's profile
Jim Finn
2658 posts in 2949 days
#8 posted 11-08-2015 03:16 PM
I had a similar experience and decided that the Stanly scraper I had was made of stainless steel. I now do not burnish the edge after sanding flat at all and it works well. I have a scraper that a friend made from an old hand saw that I do burnish and it also works well for me.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Tim's profile
Tim
3812 posts in 1989 days
#9 posted 11-08-2015 03:57 PM
There have been a few threads pop up as new that were originally posted (and answered) over a week ago… something wacky going on with underlying database around here for sure.
- MrUnix
This question got posted as two threads the first time, I saw them both at the time. Happens fairly often with the LJ software. One of the two got commented on the first time then oldnovice commented on this one today, making it active again.
MrUnix
#10 posted 11-08-2015 06:12 PM
That makes sense… glad it’s not a buglet in the database :)
