Can anyone identify this all metal hand Drill
« back to Hand Tools forum
Forum topic by Troyak posted 10-28-2015 09:23 PM 704 views 0 times favorited 6 replies Add to Favorites Watch
View Troyak's profile
Troyak
4 posts in 935 days
10-28-2015 09:23 PM
Topic tags/keywords: hand drill identify
This drill has a metal handle on it
View virgilex's profile
virgilex
5 posts in 928 days
#1 posted 11-04-2015 05:00 AM
Wow, never seen one like this before… It’s a real beauty!
View TheFridge's profile
TheFridge
9438 posts in 1479 days
#2 posted 11-04-2015 05:07 AM
- Troyak
Indeed it does
bandit571
19950 posts in 2677 days
#3 posted 11-04-2015 05:26 AM
Millers Falls No. 480
Troyak
4 posts in 935 days
#4 posted 11-04-2015 06:16 AM
Thanks for the reply
I don’t know if all the info on http://oldtoolheaven.com/hand_drills/drill5.htm is accurate. The 480 is described as having a Rotatable cap on end handle provides access to eight drill points. This drill does not have a cap on the handle. Also http://www.georgesbasement.com/gearwprs/oldno104.htm shows a 480, it has the screw on handle, and a single gear.
Thanks for looking
View HokieKen's profile
HokieKen
4954 posts in 1132 days
#5 posted 11-04-2015 01:13 PM
I don t know if all the info on http://oldtoolheaven.com/hand_drills/drill5.htm is accurate. The 480 is described as having a Rotatable cap on end handle provides access to eight drill points. This drill does not have a cap on the handle. Also http://www.georgesbasement.com/gearwprs/oldno104.htm shows a 480, it has the screw on handle, and a single gear.
Thanks for looking
- Troyak
I don’t think it’s the 480 either. From what I can find, all of the 480s were single pinion. It definitely has the look of a Millers Falls drill but I’ve never seen one with the solid frame like that. It’s possible that it started with a wooden handle and someone turned and fitted a metal one to it. Even ignoring the handle though, I can’t identify that frame. Are there any markings on the crank handle, the chuck or the drive gear?
-- Kenny, SW VA, Go Hokies!!!
View Woodknack's profile
Woodknack
11601 posts in 2373 days
#6 posted 11-04-2015 06:21 PM
Clean up the chuck and see if it has any markings.
