Table saw chipping wood
Forum topic by Quailguy posted 10-28-2015 05:51 PM 703 views 0 times favorited 9 replies Add to Favorites Watch
View Quailguy's profile
Quailguy
54 posts in 1094 days
10-28-2015 05:51 PM
I have an older Craftsman 10” contractor saw with Exacta-Rip fence. Recently I’ve noticed that the bottom edges of cut boards are chipped off. This happened both with walnut and Baltic birch plywood. I confirmed the Freud blade is perpendicular to the table, aligned to the miter slot, and no noticeable damage to the blade. What am I missing?
9 replies so far
MrUnix
6330 posts in 2101 days
#1 posted 10-28-2015 05:53 PM
What am I missing?
A ZCI maybe?
Quailguy
#2 posted 10-28-2015 06:10 PM
That may be true, but why all of a sudden? Never saw this problem before, but then again, isn’t that typical of tis hobby…
View tomsteve's profile
tomsteve
752 posts in 1122 days
#3 posted 10-28-2015 08:32 PM
how many teeth on the blade and what type of grind on the blade?
how long since it was sharpened?
its usually a sign to me its time to sharpen.
Quailguy
#4 posted 10-28-2015 08:42 PM
Freud Fusion 40 tooth. its worn off but I think its a 33? degree grind. I’ve given in reasonable use for about a year, so you may be right. Thanks
Mike
View patcollins's profile
patcollins
1650 posts in 2767 days
#5 posted 10-28-2015 08:42 PM
The bottom chips out because the blade is coming out of the wood there and it is not backed supporting it so it splinters. You can either put a sacrificial piece under it for support or a zero clearance insert.
Some wood (plywood especially) chips more than others as well as some types of blades chip more than others.
View TheFridge's profile
TheFridge
8846 posts in 1388 days
#6 posted 10-28-2015 08:58 PM
New zero clearance insert at the least
View dhazelton's profile
dhazelton
2686 posts in 2199 days
#7 posted 10-28-2015 09:55 PM
Is the blade set too high with too fast a feed rate?
Quailguy
#8 posted 10-28-2015 09:57 PM
I think it’s a sharpness issue, but the zero clearance insert theory makes sense. Off to the sharpening shop. Thanks to everyone.
View rwe2156's profile
rwe2156
2794 posts in 1383 days
#9 posted 10-29-2015 02:54 PM
As the blade got duller, you started getting more tear out.
You still need a ZCI.
