What finish do you reccomend for this table.
Forum topic by bbandu posted 10-28-2015 05:16 PM 727 views 0 times favorited 12 replies Add to Favorites Watch
View bbandu's profile
bbandu
93 posts in 1567 days
10-28-2015 05:16 PM
Ok so I have built a coffee table for the wife and I intend to leave the table natural.
What finish would you recommend that I put on the table to sustain the wear and tear of a
coffee tables normal daily life.
Remembering that I am wanting the beautiful natural color and grain of the wood show.
12 replies so far
View jmartel's profile
jmartel
7951 posts in 2173 days
#1 posted 10-28-2015 05:25 PM
Some sort of varnish. Oil based will add a bit of an amber hue, water based will be clearer. Just depends on the final look you want.
I like wiping varnishes, like General Finishes Arm-R-Seal. Easy to apply, easy to make look good. Haven’t had good luck with brushing Poly, but I haven’t tried in a while.
bbandu
#2 posted 10-28-2015 05:32 PM
I like wiping varnishes, like General Finishes Arm-R-Seal. Easy to apply, easy to make look good. Haven t had good luck with brushing Poly, but I haven t tried in a while.
- jmartel
I was looking at your Mission End tables and saw that you finished them with 5 coats of Arm-R-Seal on the top, and 4 on the rest.
All but the last coat was done in gloss, and the final coat on everything was done in Satin.
Following that, paste wax was used to give it a bit of a shine and to smooth everything out even more.
Ok a couple questions about this.
Why change from gloss to satin on the final coat?
Why apply paste wax at the end?
4998 posts in 2516 days
#3 posted 10-28-2015 05:38 PM
Just a suggestion: put something on the interior that’s not oil based, regardless of the choice for the exterior. Oil based finishes in a closed space like that will smell forever…as well as impart that smell to whatever may be inside. Use shellac, nitro lacquer, or a waterborne on the inside. Nice table, BTW.
bbandu
#4 posted 10-28-2015 05:41 PM
Just a suggestion: put something on the interior that s not oil based, regardless of the choice for the exterior. Oil based finishes in a closed space like that will smell forever…as well as impart that smell to whatever may be inside. Use shellac, nitro lacquer, or a waterborne on the inside. Nice table, BTW.
- Fred Hargis
Thanks Fred, was actually thinking about lining the inside.
This was my first coffee table as well as my first butcher block style top.
#5 posted 10-28-2015 05:52 PM
What about the bottom side of the top?
bbandu
#6 posted 10-28-2015 05:55 PM
- Fred Hargis
That is something to think about. Will keep that in mind as I decide what finish to use.
View one19's profile
one19
65 posts in 1325 days
#7 posted 10-28-2015 06:00 PM
Reminds me of a butcher block style top, so boiled linseed oil comes to mind. I’ve been very happy with the results every time I’ve used BLO.
bbandu
#8 posted 10-28-2015 06:12 PM
Reminds me of a butcher block style top, so boiled linseed oil comes to mind. I ve been very happy with the results every time I ve used BLO.
- one19
I am glad that it reminds you of a butcher block because that is what I was going for.
View JoeinGa's profile
JoeinGa
7736 posts in 2030 days
#9 posted 10-28-2015 06:23 PM
- Fred Hargis
- bbandu
Whatever you do to the outside of the top, DO NOT leave the inside of the top unfinished!
A finished outside and an unfinished inside of that top will come back and bite you in the butt.
bbandu
#10 posted 10-28-2015 06:26 PM
- Fred Hargis
- bbandu
- JoeinGa
Thanks I will not be leaving the underside of the top unfinished.
jmartel
#11 posted 10-28-2015 06:59 PM
- bbandu
By default, finishes are made in gloss. They add in particles to lower the sheen to satin, semi gloss, matte, etc. The thought is that you end up with a clearer finish with less diffraction if you do all but the last coat or two in gloss. I don’t think it really made much of a difference.
I put paste wax on to smooth it out (wax fills the pores) and to even out the sheen. Ends up with a smoother feeling finish. Not a huge difference, but I think it adds a bit of something extra.
The Entertainment center that I built was done in all satin coats of Arm-R-Seal and no paste wax (because I didn’t want to wax that whole giant thing). I don’t think it was significantly different. I’m just planning on buying satin from now on. Will still wax pieces that get handled more, though.
bbandu
#12 posted 10-28-2015 07:03 PM
- bbandu
By default, finishes are made in gloss. They add in particles to lower the sheen to satin, semi gloss, matte, etc. The thought is that you end up with a clearer finish with less diffraction if you do all but the last coat or two in gloss. I don t think it really made much of a difference.
The Entertainment center that I built was done in all satin coats of Arm-R-Seal and no paste wax (because I didn t want to wax that whole giant thing). I don t think it was significantly different. I m just planning on buying satin from now on. Will still wax pieces that get handled more, though.
- jmartel
Awesome, thanks for the explanation.
