allignment question for Supermax 19-38 drum sander
Forum topic by indychip posted 10-27-2015 05:24 PM 1757 views 0 times favorited 6 replies Add to Favorites Watch
View indychip's profile
indychip
81 posts in 2242 days
10-27-2015 05:24 PM
I have had this drum sander for about 2 months now. Best purchase in my work shop. I do a lot of end grain cutting boards and this tool has cut the sanding down to almost nothing. Of course I still have to do my final standing with a ROS, not a big deal though.
Now, the problem is that the conveyor belt has become slightly un-parallel with the drum. All of the instructions I have read and searched for say ” Just one nut will adjust the conveyor to parallel the sanding head”. But, nowhere can I find documentation as to where this magical adjusting nut is. Can somebody enlighten me on where this is? Thanks.
5072 posts in 2614 days
#1 posted 10-27-2015 05:33 PM
From the manual: If the drum is not parallel, loosen
the four socket head cap screws (along the outboard
edge of the conveyor) (Fig. 7) and raise or lower the
conveyor with the 7/16” adjustment nut to achieve
parallel alignment. Tighten the four socket head cap
screws.
Look at the outboard edge of the conveyor, right under the drum. You should see a plate with the 4 socket head screws, and it will have an opening in the side. The magic nut is in the opening, and the bolt is positioned vertically.
indychip
#2 posted 10-27-2015 05:40 PM
thanks, I know right where the 4 screws are that you mentioned, I was just hoping that there was an easier way. after all, they do say; just 1 nut will adjust it.
#3 posted 10-27-2015 06:05 PM
I guess technically the 4 screws just lock things in place..the adjustment is done with just the one bolt…but I can see your point. You would appreciate this more if you had ever had the “opportunity” to adjust the table level and parallel on a Delta 18/36. (trust me on that)
View AandCstyle's profile
AandCstyle
3154 posts in 2378 days
#4 posted 10-27-2015 10:35 PM
I would junk my Delta 18/36 before I would put myself through that “adjustment”! Fred is absolutely correct.
-- Art
View eebdoow's profile
eebdoow
53 posts in 2781 days
#5 posted 01-07-2018 01:22 AM
The Supermax manual was written by a group of mental midgets.
-- In an age of universal deceit, telling the truth is a revolutionary act -George Orwell
View splintergroup's profile
splintergroup
2253 posts in 1343 days
#6 posted 01-07-2018 03:11 PM
Mike has a great tip for fine tuning the setup you get the built in tilt adjusted as food as you can. These systems always seem to move slightly when locking things down.
